727 lesson learned #2551330
09/18/18 12:13 AM
09/18/18 12:13 AM
Minnesota, USA
humpty Offline OP
humpty  Offline OP
Minnesota, USA
Here is why you don’t do burnouts in 1st gear, do run a low band apply valve body, and do go through the trans after a differential failure. This trans was run after a rear diff failure and passed a drive test, then failed on launch with some traction. This is my buddy’s foot brake 727. Thankfully the damage was limited to the sprag itself and didn’t take more with it.
Re: 727 lesson learned [Re: humpty] #2551450
09/18/18 12:05 PM
09/18/18 12:05 PM
moparx Offline
moparx  Offline
work glad it wasn't worse !
beer
