Finally holding up its own weight #2551038
09/17/18 01:39 PM
09/17/18 01:39 PM
Texas
0
03heavy Offline OP
03heavy  Offline OP
Texas
Need some help with setting the pinion angle
Leaf springs (Caltrac’s)and a Transbrake
Re: Finally holding up its own weight [Re: 03heavy] #2551039
09/17/18 01:41 PM
09/17/18 01:41 PM
Texas
0
03heavy Offline OP
03heavy  Offline OP
Texas
Should have picture 🤷‍♂️🤷‍♂️🤷‍♂️
Re: Finally holding up its own weight [Re: 03heavy] #2551052
09/17/18 02:02 PM
09/17/18 02:02 PM
Call or contact Calvert for their advice on your car up scope
Re: Finally holding up its own weight [Re: 03heavy] #2551245
09/17/18 08:32 PM
09/17/18 08:32 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Looks nice!
Re: Finally holding up its own weight [Re: Cab_Burge] #2551256
09/17/18 09:02 PM
09/17/18 09:02 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
I agree with Cab. It is the wrong time of year for a pinion angle argument.(bad subject, beat to death....Goggle it)
Nice Duster!
"Just a Bracket car dressed up like a streetcar"
Re: Finally holding up its own weight [Re: 03heavy] #2551277
09/17/18 09:54 PM
09/17/18 09:54 PM
Minnesota, USA
humpty Offline
humpty  Offline
Minnesota, USA
What is the question?
Re: Finally holding up its own weight [Re: 03heavy] #2551313
09/17/18 11:23 PM
09/17/18 11:23 PM
Texas
0
03heavy Offline OP
03heavy  Offline OP
Texas
We suggest the pinion angle to be between 2 and 4 degrees negative at rest, as the pinion will climb 2-3 degrees at the launch, assuming the preload is roughly 1/4 turn
This is from Calvert
Re: Finally holding up its own weight [Re: 03heavy] #2551501
09/18/18 02:01 PM
09/18/18 02:01 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
Sounds right to me, I would go to 4 degrees negative to start.
What is your power level?
What type of trans?
Re: Finally holding up its own weight [Re: 03heavy] #2551506
09/18/18 02:17 PM
09/18/18 02:17 PM
Kirkland, Washington
Pacnorthcuda Offline
Calvert has answered this MANY times. 2-4 degrees down, with stated preload. You will be able to adjust preload without worrying about its effect on angle (within reason) at this setting.
Think about it...4 degrees down without bars, on a leaf spring set up works well, and the Caltracs limit spring wrap up..makes sense.
Re: Finally holding up its own weight [Re: 03heavy] #2551541
09/18/18 03:10 PM
09/18/18 03:10 PM
Texas
0
03heavy Offline OP
03heavy  Offline OP
Texas
This was directed towards the guys using a Transbrake and a 3 speed
And trying to leave hard off the brake which I thought was a common setup
But after digging around most of the guys I found to be using the Caltrac’s
Are footbraking
I was just seeing how the fast guys do it
Thanks for the reply’s folks
Re: Finally holding up its own weight [Re: 03heavy] #2551545
09/18/18 03:14 PM
09/18/18 03:14 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
5-6 degrees down is what I have been doing for years. That rear does move quite a bit
Re: Finally holding up its own weight [Re: 03heavy] #2551547
09/18/18 03:26 PM
09/18/18 03:26 PM
Minnesota, USA
humpty Offline
humpty  Offline
Minnesota, USA
I wouldn't consider our car fast, but we're at -5 degrees launching a low gear 904 at 3500rpm off the transbrake on 275 Drag Radials, 3165lbs at the line with 4.30's. The biggest issue with the transbrake has been controlling the hit to keep the tires planted. Menscer fixed the issue with shock valving.
That is a beautiful A body!
