Re: Paint question
[Re: 68SportSatvert]
#2547911
09/09/18 01:32 PM
09/09/18 01:32 PM
Posts: 3,518 Lansing, MI
70gtx440dana
Lansing, MI
Had my 70 Charger done with single stage in trunk, interior floor and underside. All the rest is base clear. I am very happy with it.
70 Road Runner 383-4 4 speed FJ5 & black guts 70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: Paint question
#2547915
09/09/18 01:35 PM
09/09/18 01:35 PM
Posts: 18,153 Mass
DAYCLONA
Mass
Do you use single stage or base/clear when painting the engine compartment, inside of the trunk and interior of the car? Thanks in advance! personally I like BC/CC on a vehicle, the idea of painting a vehicle with SS in the jambs/trunk/engine compartment, then BC/CC on the main body is just asinine IMHO, and looks like $h!t to top it off, paint the vehicle in ONE type of paint desired, and as a whole unit, not piece by piece either (another asinine process)
Re: Paint question
#2548060
09/09/18 08:10 PM
09/09/18 08:10 PM
Posts: 20,645 So Near, Yet So Far
topside
So Near, Yet So Far
Some of this depends on what you're doing: dealing with one area, driver vs. show vs. OEM, doing the whole car completely stripped down, budget... I've done it all 3 ways depending on the car. BC/CC stands up better to chemicals, bird crap, etc, easier to purchase in some systems, one formula does it all. Also easier to fix scuffs, but harder to fix chips/scratches. The factory used SS, as we know, and there's almost always a difference in appearance ("depth") between SS and BC/CC. Texture isn't a big issue to duplicate. Difference in appearance doing half/half is more noticeable to me with metallics than doing all the same, but the average non-car person will likely not notice. It's easier to get the metallics right with BC/CC than with SS. If you go with SS, by all means use a catalyzed product.
Re: Paint question
#2548414
09/10/18 03:24 PM
09/10/18 03:24 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
I used to do single stage as it was easier. I then started doing single stage urethane, straight ss for 1st coat, then mixed 50/50 with clear on second coat, then coat of just clear... but that was when everyone wanted the underside painted. Now I just use base/clear. Single stage just doesn't look as good in the end.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Paint question
[Re: Silver70]
#2552730
09/21/18 10:11 AM
09/21/18 10:11 AM
Posts: 252 southeast ky
mills.mopar
southeast ky
If budget is an issue, you could always use a cheaper clear in the areas that won't see the sun... Just an idea..
Jeff
If you love it lube it
68 dart 37 dodge coupe 71 challenger
Re: Paint question
#2593054
12/17/18 05:17 AM
12/17/18 05:17 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
I did single stage on the inside of the engine compartment because it cost me $2700 just for the paint and BC/CC would have been another 400 more...
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
Re: Paint question
[Re: Alaskan_TA]
#2593366
12/17/18 08:52 PM
12/17/18 08:52 PM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
Base / clear often alters the original paint color & hue.
Hemi Orange looks a lot more like Go Mango as just one example.
LOL - that's the truth My brother and I both had cars painted at the same time at the same place. Both cars are EV2. My car is painted in SS, his in BC/CC. He calls me up and tells me my car is too red. I freaked out. Went down there and looked at it. I went back home and compared it to some SS I bought back in 1990. My car looks spot on, his is way to light.
Re: Paint question
[Re: Morty426]
#2593587
12/18/18 03:52 AM
12/18/18 03:52 AM
Posts: 18,153 Mass
DAYCLONA
Mass
LOL - that's the truth My brother and I both had cars painted at the same time at the same place. Both cars are EV2. My car is painted in SS, his in BC/CC. He calls me up and tells me my car is too red. I freaked out. Went down there and looked at it. I went back home and compared it to some SS I bought back in 1990. My car looks spot on, his is way to light. Seeing that BC/CC has been the "norm" in the industry the last few decades, the manufacturers have decided over the years to curtail the alternatives or ALTs that were available on paint formulation, so as to simplify paint formulation and mix formulas esp with the event of computer mix programs, this resulted in many mix formulas being "averaged out", basically a "close match" if you will on one formula mix,... back in the day when mixing was done with written formulas and or color keys, some formulas could have upward of 5 different ALT's in order to achieve a correct color match, whether it was to match factory paint or repair blend of the current color on the vehicle... A correct color match can be achieved in BC/CC if you are a mixer, or have a mixer that can work with you to achieve the proper color you desire, but many factors can still influence the final result no matter how correct the finish paint color mix is, simply using a dark or light primer/sealer base/alternate shade value can effect the outcome as well as coverage, paint application technique, etc, etc, etc...
Re: Paint question
#2593762
12/18/18 02:43 PM
12/18/18 02:43 PM
topside
So Near, Yet So Far
Yup. The color you see is made up of different "toners" (think of them as base colors), mixed in at various small amounts to pull the final color in one direction or another. My '68 Road Runner W1 white had small amounts of black & ochre in it, for example; I think there were 5 toners in all to make that color. Older blues tend to be greener than contemporary blues, which tend to be redder. My best painters understood the "color wheel" and primary colors, and had an eye for moving say a blue toward the green or red part of the spectrum. One guy in particular was a genius at it, with an excellent "eye", and always kept spray-out cards he'd make to save him time on matching colors.
Re: Paint question
#2595633
12/22/18 09:43 PM
12/22/18 09:43 PM
topside
So Near, Yet So Far
We got the best bang-for-buck, best color library, and best coverage (less color needed to achieve final result) with Standox. I've also used DuPont & Nason, which were also from the same parent company, PPG, Sikkens and a couple of the "budget" brands. Spies-Hecker had their fans as well. You do get what you pay for in most respects. My Standox cars are going on 30 years and the paint looks as good as ever. My truck with Nason on it is going on 9 years, still looks the same. All were 2-part BC/CC jobs, using the recommended system (primer, sealer, etc). Also did a Nason base with a DuPont clear that came out nice & has held up fine.
