powerglide qestion #2549465
09/13/18 01:19 AM
09/13/18 01:19 AM
Iowa
coronetville Offline OP
Iowa
the car ijust bought has a aftermarket powerglide case on it would it come with a place for speedometer it or not? should be on tailshaft ? [its packed in tight]
Re: powerglide qestion [Re: coronetville] #2549589
09/13/18 01:26 PM
09/13/18 01:26 PM
Tucson AZ.
RADAMX Offline
RADAMX  Offline
Tucson AZ.
It is in the tail shaft so it depends on that.
My JW has the Ultra tail and it does not have any provisions for a speedo .
Also if it has a aftermarket output shaft it may not have a Gear inside .
So you will need to look .
Re: powerglide qestion [Re: coronetville] #2549622
09/13/18 02:40 PM
09/13/18 02:40 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Any race stuff - tailshaft housing, output shaft - will not have provisions for a speedo. You would have to use a stock gear set/output shaft and tailhousing to do that. It's just a 7/8 hole on the drivers side with a provision to bolt the speedo gear housing in.
Re: powerglide qestion [Re: coronetville] #2549776
09/13/18 10:36 PM
09/13/18 10:36 PM
Iowa
Iowa
Thanks thats what i thought i found the capped off hole looks like i will have to go electrical
Re: powerglide qestion [Re: coronetville] #2549779
09/13/18 10:42 PM
09/13/18 10:42 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Check into it but with my ATI powerglide case I can use a stock or aftermarket tail shaft. I bought a reconditioned stock one from Summit for around 40.00
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
