Re: Stock Fuel Pumps
[Re: 2BblHarold]
#2548574
09/10/18 11:22 PM
09/10/18 11:22 PM
Posts: 13,572 md
mopars4ever
md
[Re: 2BblHarold]
#2548615
09/11/18 12:56 AM
09/11/18 12:56 AM
RapidRobert
I would say a combination of ethanol & general poor quality these days. I don't have a recommendation but if you get a name for one made in the good ole US of A that'd be the way I would go.
[Re: 2BblHarold]
#2548724
09/11/18 12:11 PM
09/11/18 12:11 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
You could call the Edelbrock tech line and ask if their pump 1720 is alcohol compatible, 1-800-416-8628. Info online doesn't say, though for the Holley pump it does say not compatible, but I suspect they mean 100% not E10.
I have run into this very issue myself with off the shelf stock pumps.
[Re: 2BblHarold]
#2548829
09/11/18 03:40 PM
09/11/18 03:40 PM
Posts: 21,065 Niles , Ohio
therocks
Niles , Ohio
We use nothing but Holley pumps.Had 3 bad Carter hi buck pumps bad in a rwo.2 BBs 1 SB.Will admit one lasted a week.Put my 30 year old Holley on and it still worked.The one on my 440 has been on 20 years now.My kids 360 has been on the same.Still work great.Remans depends on the reman company.Used quite a few at work and had no problems.Going thru that many pumps something is wrong.Do they just quit leak etc?Rocky
Chrysler Firepower
[Re: 2BblHarold]
#2548839
09/11/18 03:50 PM
09/11/18 03:50 PM
Supercuda
About to go away
About to go away
up yours
Who remans fuel pumps?
No one.
Where can you get a reman fuel pump?
No where
What are you talking about?
[Re: John_Kunkel]
#2548944
09/11/18 07:28 PM
09/11/18 07:28 PM
Supercuda
About to go away
About to go away
up yours
Gonna tell us how to fit a B/RB pump onto an LA?
[Re: 2BblHarold]
#2548955
09/11/18 08:04 PM
09/11/18 08:04 PM
Posts: 2,806 Northern NJ
StukaJU87
Northern NJ
Scott
1969 Super Bee, 383/4 speed
[Re: 2BblHarold]
#2548976
09/11/18 09:01 PM
09/11/18 09:01 PM
Supercuda
About to go away
About to go away
up yours
A no name fuel pump from some Ebay seller who is so savvy that this is quote from the listing
"Surface Finish: MADE FOR UNLEADED ETHANOL GAS"
I would hope that cast aluminum and sheet metal could handle ethanol.
Try googling the manufacturer and PN and verify it. Good luck.
Just get a DELPHI MF0010 at rockauto, it specifically says "including alcohol fuels and blends" and it's substantially cheaper than some mystery Ebay seller.
[Re: 2BblHarold]
#2549926
09/14/18 12:13 PM
09/14/18 12:13 PM
Posts: 66 Mid TN
2BblHarold
Mid TN
Thanks folks! I will look into these options. :0)
[Re: 2BblHarold]
#2550230
09/15/18 10:24 AM
09/15/18 10:24 AM
Supercuda
About to go away
About to go away
up yours
The Delphi unit I posted is stock looking, cheaper than the Carter and listed as being ethanol compatible. Not sure why you want to keep rolling dice.
