Re: 90 degree oil filter adaipter
[Re: BDW]
#2546907
09/06/18 09:07 PM
09/06/18 09:07 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
I bolted it up to my mock up 5.7 block in the car last night. It will be a while until it sees pressure on my 6.1 alum block.
"Just a Bracket car dressed up like a streetcar"
[Re: BDW]
#2547037
09/07/18 01:52 AM
09/07/18 01:52 AM
Posts: 990 Norwalk, Ohio
sycboi
Norwalk, Ohio
Interesting, is it the same thread as Mopar block? Yes, 3/4-16 threads. Guys have been using them on some Jeeps and other vehicles for clearance purposes when modifications are done. V8 swaps, etc...
SuperBeast
An enforcer for the Mopar Mafia!
[Re: BDW]
#2547290
09/07/18 06:11 PM
09/07/18 06:11 PM
sycboi
Norwalk, Ohio
So how does that seal to the block? The same way an oil filter does. It has a seal, like an O-ring. It has a long threaded nut that that goes through the housing and screws on the same threads the oil filter does…
SuperBeast
[Re: BDW]
#2547294
09/07/18 06:19 PM
09/07/18 06:19 PM
Just-a-dart
Glendora Ca.
So how does that seal to the block? O ring. google Ford M-6880-A50
