90 degree oil filter adaipter #2546569
09/06/18 09:36 AM
09/06/18 09:36 AM
Glendora Ca.
Just-a-dart Offline OP
Glendora Ca.
I am working on a tube chassis car and need the oil filter spun to beside the block, or do a remote. I found this and thought others might be able to use it too. https://www.summitracing.com/parts/fms-m-6880-a50
"Just a Bracket car dressed up like a streetcar"
Re: 90 degree oil filter adaipter [Re: Just-a-dart] #2546890
09/06/18 08:32 PM
09/06/18 08:32 PM
BDW Offline
BDW  Offline
Interesting, is it the same thread as Mopar block?
Have you actually used it yet?
Re: 90 degree oil filter adaipter [Re: BDW] #2546907
09/06/18 09:07 PM
09/06/18 09:07 PM
Glendora Ca.
Glendora Ca.
I bolted it up to my mock up 5.7 block in the car last night. It will be a while until it sees pressure on my 6.1 alum block.
Re: 90 degree oil filter adaipter [Re: BDW] #2547037
09/07/18 01:52 AM
09/07/18 01:52 AM
Norwalk, Ohio
sycboi Offline
sycboi  Offline
Norwalk, Ohio
Yes, 3/4-16 threads. Guys have been using them on some Jeeps and other vehicles for clearance purposes when modifications are done. V8 swaps, etc...
SuperBeast
An enforcer for the Mopar Mafia!
Re: 90 degree oil filter adaipter [Re: Just-a-dart] #2547260
09/07/18 04:38 PM
09/07/18 04:38 PM
BDW Offline
BDW  Offline
So how does that seal to the block?
Re: 90 degree oil filter adaipter [Re: BDW] #2547290
09/07/18 06:11 PM
09/07/18 06:11 PM
Norwalk, Ohio
sycboi Offline
sycboi  Offline
Norwalk, Ohio
The same way an oil filter does. It has a seal, like an O-ring. It has a long threaded nut that that goes through the housing and screws on the same threads the oil filter does…
SuperBeast
Re: 90 degree oil filter adaipter [Re: BDW] #2547294
09/07/18 06:19 PM
09/07/18 06:19 PM
Glendora Ca.
Glendora Ca.
O ring. google Ford M-6880-A50
Re: 90 degree oil filter adaipter [Re: Just-a-dart] #2547493
09/08/18 08:40 AM
09/08/18 08:40 AM
BDW Offline
BDW  Offline
Thx for the info, putting this on the list for my Gen3 swap
