Hellcat main bearings. #2538914
08/20/18 10:50 AM
08/20/18 10:50 AM
Australia
aus370 Offline OP
aus370  Offline OP
Australia
Anyone here used the hellcat main bearings in a 6.4 .
Re: Hellcat main bearings. [Re: aus370] #2541030
08/24/18 08:32 PM
08/24/18 08:32 PM
IN
ahy Offline
ahy  Offline
IN
I have not and will share an idea.
The Hellcat bearings are probably a harder compound to deal with high cylinder pressure and rod loads. Harder also means less forgiving (dirt & clearance tolerance). If the "regular" 6.4 bearings do OK for you I would not change. If you need the tougher bearing, be careful.
Re: Hellcat main bearings. [Re: aus370] #2544996
09/03/18 11:33 AM
09/03/18 11:33 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
are you asking if any one has modified a Non Hellcat block to use the twin oiling oil Bearings?
Yes.
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: Hellcat main bearings. [Re: aus370] #2545528
09/04/18 09:55 AM
09/04/18 09:55 AM
Australia
aus370 Offline OP
aus370  Offline OP
Australia
Just trying to find if theres any benifit using them, and if they are a direct fit.
Re: Hellcat main bearings. [Re: aus370] #2545618
09/04/18 01:06 PM
09/04/18 01:06 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
Benefit= not sure, if you mod the main bearing saddle and add the grove from the main feed to the 2nd hole, I say yes.
just installing and not adding the extra oil grove, I would think no, but have never tried it .
Re: Hellcat main bearings. [Re: aus370] #2546013
09/05/18 05:36 AM
09/05/18 05:36 AM
Australia
aus370 Offline OP
aus370  Offline OP
Australia
They were a little cheaper when i looked , and i thought if there was a benifit, why not . thanks for replys.
