Re: Master cylinder bore size question
[Re: Neil]
#2543544
08/30/18 06:17 PM
08/30/18 06:17 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
If you have a 70 style front disc setup, it used a 1" bore master
The 73 style discs used a 15/16" bore manual or a 1 1/32" bore power M/C.
If you were putting a 73 style disc setup in the 70, just use the complete 73 setup in front.
[Re: Neil]
#2544310
09/01/18 04:10 PM
09/01/18 04:10 PM
Posts: 3,675 South San Francisco, Ca
70sixpkrt
I was using a 1 1/32" master cylinder and the pedal was high and very hard. Switched to a 15/16" and now the pedal goes down more and feels a little spongy. I like this better.
[Re: DoctorDiff]
#2544374
09/01/18 07:34 PM
09/01/18 07:34 PM
Posts: 3,575 The Netherlands
BigBlockMopar
The Netherlands
Spongy brakes are solved by installing residual valves. I have a modern 15/16" MC on my '73 Dart on which I installed res.valves in both front and rear line (2 lbs valve in front / 10 lbs to rear). This helped and firmed up brakepedal-feel. But it also caused the fronts to grab the disc to hard at rest. Difficult to rotate the wheels when jacked up. It cost me a full mpg in economy too. Removed the front res.valve helped release thme again and get my lost mpg back. But the calipers got a bit more spongy again. Actually, the 73 style discs used a 15/16" bore POWER or a 1 1/32" bore MANUAL master cylinder.
This is bass-ackward from what seems logical. Probably the brake pedal/MC strut is in a different hole which changed its ratio.
[Re: BcudaChris]
#2610190
01/22/19 12:11 AM
01/22/19 12:11 AM
Posts: 30,947 Oregon
AndyF
Does anyone have PN's for a 7/8" or 15/16" bore 2 bolt MC that will fit four our purposes? I ordered a 15/16" listed for a minivan, and the push rod was too large for the socket. Of course, not returnable after opening the bag. Doctor Diff has them.
[Re: Neil]
#2610197
01/22/19 12:19 AM
01/22/19 12:19 AM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
Ended up picking up a nearly complete small bolt Kelsey Hayes setup off a 71 Demon yesterday. Master cylinder part number says 1-1/32" It needs rebuilt for sure. It needs to be rebuilt? Who has their M/C rebuilt nowadays except for the restoration guys?
[Re: Kern Dog]
#2610317
01/22/19 10:03 AM
01/22/19 10:03 AM
Supercuda
About to go away
About to go away
up yours
Ended up picking up a nearly complete small bolt Kelsey Hayes setup off a 71 Demon yesterday. Master cylinder part number says 1-1/32" It needs rebuilt for sure. It needs to be rebuilt? Who has their M/C rebuilt nowadays except for the restoration guys? Guys who are tired of poorly made foreign junk.
[Re: AndyF]
#2610448
01/22/19 03:16 PM
01/22/19 03:16 PM
Posts: 403 Colorado front range
BcudaChris
Indeed he does. I got my adapter plate and other specialty items from him over the years, and my car will be wearing his Viper setup when I get to big brakes. Unfortunately, my budget balks over the premium he is compelled to charge for such things. I totally get the economics of the business model, and swing as much of my cash as I can to the good Doctor, you Andy and other vendors that keep the Mopar community getting faster (and properly slowed with their passion, dedication and engineering skills, and by bringing products to market so us weekend wrenches spend more time wrenching and driving, and less time playing engineer, fabricating and sorting things out.
