Re: Indy aluminum blocks
[Re: racerx]
#2542756
08/28/18 09:40 PM
08/28/18 09:40 PM
Posts: 4,540 Motor City
6PKRTSE
Motor City
Race Winning brands who is buying up everything these days has now bought out a larger share of Dart Machinery. Maybe with time we can get them to make both iron and alum big blocks and small blocks?
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: racerx]
#2550530
09/16/18 03:51 AM
09/16/18 03:51 AM
Posts: 1,098 Massillon, Ohio
cudatom
Massillon, Ohio
More KBs are about 12 to 15 weeks out.The lowdeck will not be available for the future although that could change with PROVEN demand. It is true that several lowdecks were made for some of the back ordered pieces, but these were a total nightmare,and insane to produce from a cost standpoint. I have the first wedge that I have done from soup to nuts ready to put some fire in the hole in the next day or so. I will say SO far I have been pretty happy with the way it went together. NOt a total fire breather but motor should make around 880 to 900. We shall see and I will let you guys know what I find. Todd Any fire in the hole on this yet? I want a low deck. Really would prefer a KB but since it doesn't appear to be in the cards will have to go with Indy. Damn I don't want to give them my money. Russ is such a you know what I really hate spending my money on their stuff even if it is thru a dealer.
Ok
[Re: sasquatch]
#2550592
09/16/18 12:45 PM
09/16/18 12:45 PM
Posts: 4,394 The Pale Blue Dot
Skeptic
The Pale Blue Dot
....The lowdeck will not be available for the future although that could change with PROVEN demand. It is true that several lowdecks were made for some of the back ordered pieces, but these were a total nightmare,and insane to produce from a cost standpoint. Todd What sort of commitment are you looking for as "PROVEN" demand? Given the cost of stock blocks and all the band aids to hold them together there is a need, but I understand that there is a vast gulf from paying 500(+) for a used 230 block then girdles/aluminum caps+ additional machining and a 7500 KB unit.
[Re: Skeptic]
#2550599
09/16/18 01:03 PM
09/16/18 01:03 PM
Posts: 12,379 Taxes & Virus's R-US, NY
Dragula
When the blocks were a lot cheaper, they weren't selling like the other brands. Now that most of the previous suppliers are out, the cost inevitably goes up to buy one. Let alone the manufacturing expenses and tooling.
I was able to go to my local dodge dealer and pick them up. I think I paid just under $3k for that one.
I would say history has shown, the demand wasn't there, and probably still isn't. I am in the same boat...When I called around this winter, nobody had anything in stock.
For me, its cash and carry...Not going to sit back for months wondering about my nearly $8k investment. You either have them or you don't.
If I was one of those manufacturers fighting with a foundry and all my machines were sitting. I would have called a billet supplier and at least kept the machinery rolling as well as development. These is not an easy field to make money for sure. But as a consumer, its still important where my money goes.
[Re: Dragula]
#2550617
09/16/18 01:52 PM
09/16/18 01:52 PM
Posts: 20,116 PA.
pittsburghracer
"Little"John
"Little"John
PA.
These posts always end up the same by the same members every-time. Some guys are just meant to run concrete filled stock crap crap with girdles (LOL) on them. I wonder where the costs savings comes in.
[Re: hemicar1971]
#2550919
09/17/18 07:36 AM
09/17/18 07:36 AM
Posts: 4,049 Mo.
racerx
Mo.
KBs are just around the corner to the public. There are two companies machining the new design raw cast blocks to your specs. The blocks are a work of art and almost to pretty to use. Blocks are expect to handle all that one can toss into them. you got me any ideal what the new KB block weigh?
[Re: racerx]
#2551170
09/17/18 06:01 PM
09/17/18 06:01 PM
Posts: 1,823 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
KBs are just around the corner to the public. There are two companies machining the new design raw cast blocks to your specs. The blocks are a work of art and almost to pretty to use. Blocks are expect to handle all that one can toss into them. you got me any ideal what the new KB block weigh? IIRC, 110 lbs. bare
[Re: Sammy]
#2551218
09/17/18 07:27 PM
09/17/18 07:27 PM
Posts: 4,049 Mo.
racerx
Mo.
KBs are just around the corner to the public. There are two companies machining the new design raw cast blocks to your specs. The blocks are a work of art and almost to pretty to use. Blocks are expect to handle all that one can toss into them. you got me any ideal what the new KB block weigh? IIRC, 110 lbs. bare Tnat"s Not bad...actually I thought they were a lot heavier...Thaxs.
[Re: racerx]
#2551341
09/18/18 12:37 AM
09/18/18 12:37 AM
Posts: 5,103 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
I believe the new KB might weigh a little more do to the improvements to the new support in the lifter area and a few other things such as the new billet main caps. Is the weight of 110lbs on the old KB blocks or the new KB block. When I am up at FHO I will ask Tim if he has calculated the weight of the new block and what that block was machined for. Even if the new blocks are 5 more lbs that is a huge weight saving over a Iron block. If the iron block is filled the weight saving could be over 200 lbs.
1971 HEMI E BODY REGISTRY
