Re: D400 - Should I convert from Manual to Auto?
[Re: 68Cbarge]
#2559918
10/06/18 03:40 PM
10/06/18 03:40 PM
Posts: 15,976 Chilliwack B.C. Canada
RUNCHARGER
I have to agree a Cummins 12V would be the way to go, you'd have to gear it up though. They're about done at 2000RPM.
Sheldon
[Re: poorboy]
#2561318
10/09/18 10:41 AM
10/09/18 10:41 AM
Posts: 43,517 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
I have no doubt that a 727 can be built to do the job, but at what cost?
There is a pretty signigifent different difference between a high power motor abusing a trans for 7-12 seconds, or rock crawling at very slow speeds and a 6 mile 6% uphill grade pulling 20,000 lbs. Ask Rhinodart how those 727s and their derivatives hold up dragging heavy loads across the country. Gene I know a 48RE is a 727 derivative but throwing all the electronic garbage and weak overdrive is what killed mine! Don't forget I lunched 5 NV4500's and 2 G56 Mercedes transmissions too! I am still contemplating what to put in my D700 as it has a 361 big block and I believe a 435 now.
JB Rhinehart, Realist
A-Body's RULE!
[Re: Truck Y'all !]
#2564225
10/15/18 02:10 AM
10/15/18 02:10 AM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
[Re: ahy]
#2564303
10/15/18 10:48 AM
10/15/18 10:48 AM
Rhinodart
Rhinotruck
Rhinotruck
I like that vintage Dodge truck... both the 400 and 700 are nice.
Does the 700 have a 2 speed rear? I believe it is a 5-speed, I haven't had it on the road yet and it doesn't have the extra switch for the 2-speed rear...
A-Body's RULE!
