Need to add two gauges, water temp and oil pressure #2539384
08/21/18 01:05 AM
08/21/18 01:05 AM
Motown, Mi
P
PAULS_340 Offline OP
P
Motown, Mi
Need to add electric water temp and oil pressure gauges. Is there a benefit to mechanical oil pressure over electric? Friend has NOS Mopar Performance set. I thought I was going to get electric oil pressure. What say you? Thanks.
Still looking for LM29H1B415501, '71 Demon 340
Re: Need to add two gauges, water temp and oil pressure [Re: PAULS_340] #2539398
08/21/18 01:33 AM
08/21/18 01:33 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I prefer mechanical for both. I don't want a possibility of misinterpretation, just what's actually happening right now.
Only electric gauge in my racecar is a digital voltmeter, because it takes basically no power to operate.
Re: Need to add two gauges, water temp and oil pressure [Re: PAULS_340] #2539405
08/21/18 02:01 AM
08/21/18 02:01 AM
Kirkland, Washington
Pacnorthcuda Offline
OK,
Mechanicals have always been thought of as more accurate, simpler in operation, and usually meant "full sweep" ---270 degrees vs about 120.
There are exceptions. As far as brands, AutoMeter makes great value-for-the-dollar stuff.
Re: Need to add two gauges, water temp and oil pressure [Re: PAULS_340] #2539407
08/21/18 02:20 AM
08/21/18 02:20 AM
AndyF Offline
AndyF  Offline
I don't think there is a problem these days with electric gauges. A mechanical water temp gauge is really a hassle. A mechanical oil pressure gauge isn't as bad but you're still bringing hot oil into the passenger compartment. I still have a mechanical vacuum gauge and oil pressure gauge in my car but next time I redo the console I'll switch everything over to electrical.
In the current console I have a tach in the center and then oil pressure, vacuum, water temp and AFR in the corners.
Re: Need to add two gauges, water temp and oil pressure [Re: PAULS_340] #2539431
08/21/18 05:06 AM
08/21/18 05:06 AM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Be sure to ground them back to the motor and not to the dash frame...
DAMHIK...
I can tell you for a fact that if you crank up the stereo it will peg the gauges... runaway
...FAFO...
Re: Need to add two gauges, water temp and oil pressure [Re: PAULS_340] #2539453
08/21/18 08:55 AM
08/21/18 08:55 AM
E
earlymopar Offline
earlymopar  Offline
E
The only problem I see with a mechanical water temp gauge is the size of the sending unit which requires a corresponding large hole in the firewall.
Mechanical oil pressure gauges do not bring hot oil into the car interior. In any I have had, the oil runs a couple of inches into the tube (still in the engine bay) and the rest of the tube is pressurized air which is what drives the gauge.
- EM
Re: Need to add two gauges, water temp and oil pressure [Re: earlymopar] #2539473
08/21/18 10:48 AM
08/21/18 10:48 AM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
- EM
Let the line break at the gauge and see what happens.
Re: Need to add two gauges, water temp and oil pressure [Re: Pacnorthcuda] #2539481
08/21/18 10:56 AM
08/21/18 10:56 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Originally Posted By Pacnorthcuda
OK,
About 20 years ago that was true. Not today
Don't be the exception.
Re: Need to add two gauges, water temp and oil pressure [Re: PAULS_340] #2539498
08/21/18 11:33 AM
08/21/18 11:33 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
I understand ALL the advantages of mechanical. Had them in the past. We can all pull it the "it's been fine for me" but to bring pressurized oil in the interior is a poor idea.
Re: Need to add two gauges, water temp and oil pressure [Re: Magnum] #2539510
08/21/18 11:53 AM
08/21/18 11:53 AM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
Had a line break on me a long time ago. Didn't have any tools on me with the exception of Leatherman I kept on my belt. Ended up driving twenty minutes home with one hand under the dash pinching the line off with those pliers. Never did get the stains out of the carpet and had to replace it later on. Been electric Autometer gauges ever since.
Re: Need to add two gauges, water temp and oil pressure [Re: PAULS_340] #2539563
08/21/18 01:46 PM
08/21/18 01:46 PM
AndyF Offline
AndyF  Offline
I use #3 braided steel lines for the oil pressure line but I'd rather not have it in the interior of the car if I can avoid it. So next time I update the gauge panel I'll switch to electric. I doubt there is an accuracy issue and the electrical gauges are easier to deal with.
Re: Need to add two gauges, water temp and oil pressure [Re: PAULS_340] #2539571
08/21/18 01:54 PM
08/21/18 01:54 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Marshall insterments has some nice electric gauges, and they also have some that have programable warning lights with a remote if you want.
Re: Need to add two gauges, water temp and oil pressure [Re: 71birdJ68] #2539576
08/21/18 02:00 PM
08/21/18 02:00 PM
moparx Offline
moparx  Offline
at one time, didn't someone offer an "isolater", similar as used in mechanical fuel gauges, for oil pressure gauges ?
beer
Re: Need to add two gauges, water temp and oil pressure [Re: PAULS_340] #2539737
08/21/18 07:13 PM
08/21/18 07:13 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I should mention that if one uses a mechanical oil pressure gauge, use a metal line instead of the cheap plastic one that's usually supplied. Or use a braided stainless line, but that stuff's abrasive to whatever it might rub against.
I like Moparx's suggestion of an isolator, though I don't know how well it'd work at oil pressure #s.
I haven't had one gauge leak in 30 years. Only one that did was the plastic crap I used one time before that; it was pinched at the gauge fitting.
As for feeding the water temp sensor through the firewall, I've always found a hole already there somewhere so I didn't have to break out the drill.
Re: Need to add two gauges, water temp and oil pressure [Re: PAULS_340] #2539775
08/21/18 10:01 PM
08/21/18 10:01 PM
Missouri
randavis Offline
randavis  Offline
Missouri
I use a mechanical oil pressure gauge. I plumbed it with two stainless braided lines and use a bulkhead fitting in the firewall. I also use a tee in the block and keep the sending unit for the light.
74 Challenger, bought it new. In 1978 I replaced the original 318 with a 446 and 727. Mild cam, Jardine headers, and Holley Sniper EFI.
New engine! 511" RB, Edelbrock Performer RPM heads, Eagle rotating assy, Comp hyd roller cam, Doug's 2" headers.
Re: Need to add two gauges, water temp and oil pressure [Re: pushbutton] #2539935
08/22/18 09:51 AM
08/22/18 09:51 AM
E
earlymopar Offline
earlymopar  Offline
E
Well duh. Of course that would happen. But there is nothing in the car until you open the end of the tube. The same thing is true with your heater hose!
- EM
Re: Need to add two gauges, water temp and oil pressure [Re: PAULS_340] #2540040
08/22/18 02:55 PM
08/22/18 02:55 PM
Cab_Burge Online work
Cab_Burge  Online Work
I use to use the mechanical race gauges only, but not since I had a Autometer water temps read 40 F hotter than the water temps where in the upper radiator hose water with the electric water pump circulating the water shock The gauge was reading 145F and I stuck my finger into the radiator and it was right at body temperatures, 98.F according to a high dollar heating and air conditioning pocket thermometer shruggy
I've seen more than one mechanical temp. gauge read bad since then with other good brands puke
It is your choice, the new electric digital gauges are very accurate according to other older mechanical gauges as well as new analog electric gauges used on the same motor at the same time work scope
Re: Need to add two gauges, water temp and oil pressure [Re: MarkZ] #2540184
08/22/18 09:22 PM
08/22/18 09:22 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
I had a problem with the brass fitting, but it was my own fault. I hadn't connected the brass ferrule properly. I didn't have any tools so I was driving back home with the line folded but hot oil still seeping. But again, my fault. After that, never had an issue with the gauge.
Facts are stubborn things.
Re: Need to add two gauges, water temp and oil pressure [Re: larrymopar360] #2540322
08/23/18 09:33 AM
08/23/18 09:33 AM
London, England
Gavin Offline
Gavin  Offline
London, England
Honestly, it's a myth that mechanical are somehow inherently more accurate than electrical. In both cases you are taking a physical property like pressure of temperature and converting it to a gauge needle position. The accuracy is only as good as the measurement and the conversion. Every modern car uses electrical/electronic gauges for everything, including the speedo which has legal requirements for accuracy. So the accuracy of your gauge is down to the quality of the design & construction more so than the technology. Also, if we take a step backwards, how accurate do we need most gauges to be anyway? Realistically if they are within 5% of reality that's enough in most applications, and from a design/manufacturing perspective that is not really challenging.
In this day and age I wouldn't even consider a mechanical gauge unless there was some nostalgic appeal or you already had them for free.
Re: Need to add two gauges, water temp and oil pressure [Re: Gavin] #2540354
08/23/18 11:09 AM
08/23/18 11:09 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
I agree, they quit using direct mechanical gauges in large airplanes way back in the early thirties.
