Re: SMALL BLOCK LIFTER BORE CLEARENCE
[Re: moparmacka]
#2539172
08/20/18 05:55 PM
08/20/18 05:55 PM
Posts: 4,457 Washington
madscientist
Washington
Is 0.003” lifter bore clearence too much in a 59 degree solid roller application? These bores are iron and not bushed. Thanks Too much for me.
[Re: moparmacka]
#2539220
08/20/18 07:53 PM
08/20/18 07:53 PM
Posts: 4,205 New York
polyspheric
New York
X2 Too loose, leaks away oil pressure and allows side thrust.
Boffin Emeritus
[Re: polyspheric]
#2539258
08/20/18 09:08 PM
08/20/18 09:08 PM
Posts: 20,116 PA.
pittsburghracer
"Little"John
"Little"John
PA.
If you decide to run it I would recommend taking the extra time to tube the block. After having an issue last year and seeing how much oil shoots around those roller lifters I will never prep another block without doing it. Even on a planned solid lifter built.
[Re: mhead]
#2539283
08/20/18 10:01 PM
08/20/18 10:01 PM
Posts: 20,116 PA.
pittsburghracer
"Little"John
"Little"John
PA.
How does the hydraulic lifters get by with out tubing the blocks?I understand they aren't going to see the rpm's as the solid roller but?My current car we tubed the block and all is good for four years now.Just freshened it and all good.I'm currently putting together another for son with solid flat tappet without it being tubed so very interested the post. He said in his post that he’s going with a roller cam. Tubing the block works great with both solid and roller lifter cams.
[Re: mhead]
#2539303
08/20/18 10:38 PM
08/20/18 10:38 PM
Posts: 20,116 PA.
pittsburghracer
"Little"John
"Little"John
PA.
So is the idea to tube to just keep more oil to the bottom end?How many guy's use solid flat or roller with out tubing?I suppose it keeps extra oil of top of crank also. How many guys? I’m betting quite a few because I am always hearing of guys that have oiling issues. I was shocked to see exactly how much oil was coming out of the lifter bores when we primed his engine with the intake off. Lots of wasted oil that could be used for rod and main bearing oiling. Never again for me. I will send out a block for cleaning and mag work then bring it home to tube.
[Re: mhead]
#2539306
08/20/18 10:41 PM
08/20/18 10:41 PM
madscientist
Washington
So is the idea to tube to just keep more oil to the bottom end?How many guy's use solid flat or roller with out tubing?I suppose it keeps extra oil of top of crank also. Too many guys aren't doing the simple tube fix. Every solid lifter engine should have it done.
[Re: RapidRobert]
#2539437
08/21/18 07:08 AM
08/21/18 07:08 AM
Posts: 20,116 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I ain't sure how much clearance I had but it was too much & it made the oil psi drop dangerously low after a bit of running. I'm gonna tube that block/go with solids. Hopefully it works out for you but I think the added clearance will mess with lifter rotation. We put a used 610 lift roller in my sons 360 and it runs like a beast going 6.54@3200 pounds.
[Re: pittsburghracer]
#2539593
08/21/18 02:31 PM
08/21/18 02:31 PM
RapidRobert
Hopefully it works out for you but I think the added clearance will mess with lifter rotation. Good point! (& noted). Thank you.
[Re: moparmacka]
#2539704
08/21/18 06:11 PM
08/21/18 06:11 PM
madscientist
Washington
It would appear when Mopar machined their after market blocks they opened the bores to approx. 0.906” for the 0.904” lifter. This is ok for a flat tappet lifter however, most of the solid roller lifters available are 0.903” diameter, which is where the extra clearence is from. I guess they figure people building a solid roller will bush the block because of the uncovering of the oil gallery problem. I heard of this with the Mopar a Hemi blocks. Wonder if the 48 degree blocks are the same? What block are you using? I have 3 X blocks, one of which was brand new and an R block and none of them has lifter bores that big.
[Re: moparmacka]
#2539944
08/22/18 10:30 AM
08/22/18 10:30 AM
madscientist
Washington
340 Siamese resto block. Pretty much 59 degree R3 with the valley machined for wet sump. Can’t remember the pn. Well then that really sucks big time. I'm going to dig out the R block and double check that again.
