Need to add two gauges, water temp and oil pressure
#2539384
08/21/18 01:05 AM
08/21/18 01:05 AM
Posts: 1,043 Motown, Mi
PAULS_340
Motown, Mi
Need to add electric water temp and oil pressure gauges. Is there a benefit to mechanical oil pressure over electric? Friend has NOS Mopar Performance set. I thought I was going to get electric oil pressure. What say you? Thanks.
Still looking for LM29H1B415501, '71 Demon 340
Re: Need to add two gauges, water temp and oil pressure
[Re: PAULS_340]
#2539407
08/21/18 02:20 AM
08/21/18 02:20 AM
Posts: 30,994 Oregon
AndyF
I don't think there is a problem these days with electric gauges. A mechanical water temp gauge is really a hassle. A mechanical oil pressure gauge isn't as bad but you're still bringing hot oil into the passenger compartment. I still have a mechanical vacuum gauge and oil pressure gauge in my car but next time I redo the console I'll switch everything over to electrical.
In the current console I have a tach in the center and then oil pressure, vacuum, water temp and AFR in the corners.
[Re: PAULS_340]
#2539431
08/21/18 05:06 AM
08/21/18 05:06 AM
Posts: 5,100 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
Be sure to ground them back to the motor and not to the dash frame... DAMHIK... I can tell you for a fact that if you crank up the stereo it will peg the gauges...
...FAFO...
[Re: earlymopar]
#2539473
08/21/18 10:48 AM
08/21/18 10:48 AM
Posts: 1,565 tennessee
pushbutton
tennessee
The only problem I see with a mechanical water temp gauge is the size of the sending unit which requires a corresponding large hole in the firewall.
Mechanical oil pressure gauges do not bring hot oil into the car interior. In any I have had, the oil runs a couple of inches into the tube (still in the engine bay) and the rest of the tube is pressurized air which is what drives the gauge.
- EM Let the line break at the gauge and see what happens.
[Re: Pacnorthcuda]
#2539481
08/21/18 10:56 AM
08/21/18 10:56 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
OK, Mechanicals have always been thought of as more accurate, simpler in operation, and usually meant "full sweep" ---270 degrees vs about 120.
About 20 years ago that was true. Not today
[Re: PAULS_340]
#2539498
08/21/18 11:33 AM
08/21/18 11:33 AM
Posts: 5,788 Hamilton, Ontario Canada
Magnum
I understand ALL the advantages of mechanical. Had them in the past. We can all pull it the "it's been fine for me" but to bring pressurized oil in the interior is a poor idea.
[Re: Magnum]
#2539510
08/21/18 11:53 AM
08/21/18 11:53 AM
Posts: 4,404 Michigan
MarkZ
Worthy
Worthy
I understand ALL the advantages of mechanical. Had them in the past. We can all pull it the "it's been fine for me" but to bring pressurized oil in the interior is a poor idea. Had a line break on me a long time ago. Didn't have any tools on me with the exception of Leatherman I kept on my belt. Ended up driving twenty minutes home with one hand under the dash pinching the line off with those pliers. Never did get the stains out of the carpet and had to replace it later on. Been electric Autometer gauges ever since.
[Re: PAULS_340]
#2539571
08/21/18 01:54 PM
08/21/18 01:54 PM
Posts: 4,449 Morristown Tn.
71birdJ68
Morristown Tn.
Marshall insterments has some nice electric gauges, and they also have some that have programable warning lights with a remote if you want.
[Re: PAULS_340]
#2539775
08/21/18 10:01 PM
08/21/18 10:01 PM
Posts: 141 Missouri
randavis
Missouri
I use a mechanical oil pressure gauge. I plumbed it with two stainless braided lines and use a bulkhead fitting in the firewall. I also use a tee in the block and keep the sending unit for the light.
74 Challenger, bought it new. In 1978 I replaced the original 318 with a 446 and 727. Mild cam, Jardine headers, and Holley Sniper EFI. New engine! 511" RB, Edelbrock Performer RPM heads, Eagle rotating assy, Comp hyd roller cam, Doug's 2" headers.
[Re: PAULS_340]
#2540040
08/22/18 02:55 PM
08/22/18 02:55 PM
Posts: 43,116 Bend,OR USA
Cab_Burge
I use to use the mechanical race gauges only, but not since I had a Autometer water temps read 40 F hotter than the water temps where in the upper radiator hose water with the electric water pump circulating the water The gauge was reading 145F and I stuck my finger into the radiator and it was right at body temperatures, 98.F according to a high dollar heating and air conditioning pocket thermometer I've seen more than one mechanical temp. gauge read bad since then with other good brands It is your choice, the new electric digital gauges are very accurate according to other older mechanical gauges as well as new analog electric gauges used on the same motor at the same time
[Re: MarkZ]
#2540184
08/22/18 09:22 PM
08/22/18 09:22 PM
Posts: 15,826 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I understand ALL the advantages of mechanical. Had them in the past. We can all pull it the "it's been fine for me" but to bring pressurized oil in the interior is a poor idea. Had a line break on me a long time ago. Didn't have any tools on me with the exception of Leatherman I kept on my belt. Ended up driving twenty minutes home with one hand under the dash pinching the line off with those pliers. Never did get the stains out of the carpet and had to replace it later on. Been electric Autometer gauges ever since. I had a problem with the brass fitting, but it was my own fault. I hadn't connected the brass ferrule properly. I didn't have any tools so I was driving back home with the line folded but hot oil still seeping. But again, my fault. After that, never had an issue with the gauge.
Facts are stubborn things.
[Re: larrymopar360]
#2540322
08/23/18 09:33 AM
08/23/18 09:33 AM
Posts: 1,756 London, England
Gavin
London, England
Honestly, it's a myth that mechanical are somehow inherently more accurate than electrical. In both cases you are taking a physical property like pressure of temperature and converting it to a gauge needle position. The accuracy is only as good as the measurement and the conversion. Every modern car uses electrical/electronic gauges for everything, including the speedo which has legal requirements for accuracy. So the accuracy of your gauge is down to the quality of the design & construction more so than the technology. Also, if we take a step backwards, how accurate do we need most gauges to be anyway? Realistically if they are within 5% of reality that's enough in most applications, and from a design/manufacturing perspective that is not really challenging. In this day and age I wouldn't even consider a mechanical gauge unless there was some nostalgic appeal or you already had them for free.
