Re: My new heads are killing me need help
[Re: 70dusterjohn]
#2538601
08/19/18 05:34 PM
08/19/18 05:34 PM
Posts: 20,158 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Just because the heads are better doesn’t automatically mean you jet up. You may be to Rich now or issues with the carb from sitting
[Re: pittsburghracer]
#2538614
08/19/18 06:08 PM
08/19/18 06:08 PM
Posts: 4,457 Washington
madscientist
Washington
Just because the heads are better doesn’t automatically mean you jet up. You may be to Rich now or issues with the carb from sitting That was where I was heading. He thinks he's lean but he very well could be rich. The plugs would give a better idea which way to go.
[Re: 70dusterjohn]
#2538636
08/19/18 07:28 PM
08/19/18 07:28 PM
Posts: 566 Texas
RustyM
Texas
Can you get or borrow and AFR guage? Can you get to a chassis dyno to get help in trouble shooting and dialing the car up? Is it blowing black smoke, a dog at idle/off idle. Somehow i think you would know if its "that" rich. Can you get someone to video a burn out and a run ? What does engine vacuum look like at idle in neutral and i gear?
Are the plugs black and sooty or white as snow?
How long did your fuel sit? Down here is "really, really" easy to have ones fuel turn to engine puke solution- wont run for squat. Checked floats/fuel pressure?
Is distributer locked out or on a timing curve- if on a curve, make sure curve is still intact( nothing gave up in distributer)
we recently had an MSD issue, actually the connector between distributer and msd box- i check that all the time now- grin.
Sure hope you can find your gremlin. How are water temps? Any pressure in the cooling system after the runs?
[Re: 70dusterjohn]
#2538658
08/19/18 08:15 PM
08/19/18 08:15 PM
Posts: 14,492 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I’d see about borrowing a known good carb off a somewhat similar combo.
[Re: fast68plymouth]
#2538672
08/19/18 08:45 PM
08/19/18 08:45 PM
Posts: 20,158 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Some guys laugh at me for never having an engine on a dyno in 44 years but having a RacePak in my car gives me info on every pass, not just in the dyno room.
[Re: 70dusterjohn]
#2538687
08/19/18 09:16 PM
08/19/18 09:16 PM
Posts: 11,708 Portage,michigan
B3422W5
Portage,michigan
Which spark box are you using? The only thing i have ever had go bad that killed a ton of ET was a Digital 6 box. Took half a season to find the problem. Swapped it and car came back. It would cause a miss in second and third gear was the symptom
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: Locomotion]
#2538700
08/19/18 09:44 PM
08/19/18 09:44 PM
B3422W5
Portage,michigan
* Jet for MPH. * Squirters & pump cams for 60'
Be careful so one doesn't overlap the other. (i.e.: too much jet can mask a need for bigger squirters and/or a bigger (longer squirting) pump cam.
Smaller squirters will increase the duration of the squirt and bigger squirters will shorten the duration of a given pump cam. You don't want the squirt any longer or shorter than necessary because it will mess up the A/F ratio of the main metering system (jets). Yep. All that stuff contributes to optimal ET’s. But his car is off 8 tenths or more.
#2538702
08/19/18 09:46 PM
08/19/18 09:46 PM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
John I have a good running 1050 Quickfuel I could let you use just to see if it changes at all. I work in Kent not to far from you. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: 70dusterjohn]
#2538718
08/19/18 10:13 PM
08/19/18 10:13 PM
Posts: 20,158 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I know you can’t compare carb to carb but my old high 9 oldschool (906 heads) build had 99 jets in my 1050 carb. My 8.50 build with 440-1 heads had 90-91’s Jets in the same carb
