piston top material removal/balancing Q #2538313
08/18/18 11:50 PM
08/18/18 11:50 PM
RapidRobert Offline OP
I'm thinking I may need to cut an intake valve notch in my flat top pistons. According to my figuring a notch 2.02 dia/.039" deep will remove 1.97 CC's with a weight of that material being 5.32 grams. Will this 5.32 gram reduction mess up my balance? 360 race app cast crank ext balance cast pistons. Bobweight 2189. piston (each) 617. pin 153. rings (set) 58. rod (recip) 223. rod (rotating) 1032 (a pair). rod bearings (pair) 102. oil (estimated) 4 grams. thank you for your time.
Re: piston top material removal/balancing Q [Re: RapidRobert] #2538320
08/19/18 12:09 AM
08/19/18 12:09 AM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
No worries, you will only likely be taking an eyebrow out of the piston, so betting less than a gram per piston for balance purposes.
Re: piston top material removal/balancing Q [Re: 4406bbl] #2538330
08/19/18 12:25 AM
08/19/18 12:25 AM
I missed that! I was calculating a "cylinder" .039" deep and 2.02" dia when in actuality with the 18 deg angle it WILL be eyebrow. Thank you, I owe ya one! Sometimes it ain't WHAT you know it is WHO you know. EDIT the Sealed Power H405P (I might be off on that #), have 4 notches for a listed total of 10CC & I have set somewhere so I will find em for a visual.
