Pics of your turbo setups? #2538184
08/18/18 05:32 PM
08/18/18 05:32 PM
CO
crankn101 Offline OP
CO
I would like to see some pics of turbo setups if anyone has them.
Im torn between a procharger or a turbo system, if I knew how to rig up a turbo and keep it under the hood that would help a lot.
For what its worth my car is a 70' RR, but im open for pics of any muscle cars with turbos under the hood.
Re: Pics of your turbo setups? [Re: crankn101] #2538186
08/18/18 05:35 PM
08/18/18 05:35 PM
CO
CO
Someone mentioned using a stock exhaust manifold of some type and run it upside down and reversed.
Is that a big restrictive point or is that not important with a turbo car?
Re: Pics of your turbo setups? [Re: crankn101] #2538418
08/19/18 02:31 AM
08/19/18 02:31 AM
Nampa, Idaho
Moparmatts72 Offline
Nampa, Idaho
Here's the set up in my 67 dart, I bought the car with the set up already made but it fits under a stock hood, he used headmen block hugger headers and fabbed the rest, uses twin air/water intercooler located inside the fenders just behind the headlights. I got the car with all of the set up minus the motor he built for it, no biggie already have my engine just waiting on a few parts to drop it in.
Re: Pics of your turbo setups? [Re: crankn101] #2538420
08/19/18 02:39 AM
08/19/18 02:39 AM
CO
CO
Thanks for the pic.
Thats a clean setup right there, nice and symmetrical.
Im just not sure if I want an engine compartment that full, I already have to deal with a Powerstroke.
Re: Pics of your turbo setups? [Re: crankn101] #2538450
08/19/18 08:32 AM
08/19/18 08:32 AM
Mo.
racerx Offline
racerx  Offline
Mo.
iagree.....nice and clean,is this on a stock block
Re: Pics of your turbo setups? [Re: crankn101] #2538458
08/19/18 09:48 AM
08/19/18 09:48 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Here's some early photo's of Dizusters 360 sb turbo car. Small 1 7/8" truck manifolds. Car has been 9.55@142, 3750lbs.
Doug
2011-07-24_10-22-26_445.jpg2011-07-24_10-22-42_160.jpg2011-07-24_10-23-32_740.jpg253.jpg
Re: Pics of your turbo setups? [Re: racerx] #2538544
08/19/18 01:41 PM
08/19/18 01:41 PM
Nampa, Idaho
Nampa, Idaho
The motor he built orignally was a stock 360 block base 408 stroker. I went with a Ritter block for mine.
Re: Pics of your turbo setups? [Re: crankn101] #2538592
08/19/18 05:11 PM
08/19/18 05:11 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
Still a work in progress... going to move the engine back some yet also.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Pics of your turbo setups? [Re: crankn101] #2538606
08/19/18 05:45 PM
08/19/18 05:45 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Dang Sliver you building a beast
Re: Pics of your turbo setups? [Re: crankn101] #2538637
08/19/18 07:34 PM
08/19/18 07:34 PM
California
slowfab Offline
slowfab  Offline
California
Here is mine. Way more going on here with A/C and all.
Re: Pics of your turbo setups? [Re: crankn101] #2538802
08/20/18 01:14 AM
08/20/18 01:14 AM
IL
furious70 Offline
furious70  Offline
IL
Mine's not the prettiest, but running since 2012. van/RV manifolds turned upside down.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Pics of your turbo setups? [Re: FastmOp] #2539030
08/20/18 02:08 PM
08/20/18 02:08 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
Was just going to be a cheap as can do build with a stock 5.7, but since bought forged parts as I know I won't be able to keep the boost low enough to keep cast parts together laugh2
Re: Pics of your turbo setups? [Re: crankn101] #2539331
08/20/18 11:29 PM
08/20/18 11:29 PM
Pa. U.S.A.
moparborn Offline
moparborn  Offline
Pa. U.S.A.
Here is my setup.
Re: Pics of your turbo setups? [Re: crankn101] #2539347
08/20/18 11:47 PM
08/20/18 11:47 PM
CO
CO
Thanks for the pictures, fellas.
If I ever build a strip car it will be a turbo engine, but I think thats just too darn crowded for a street setup.
Re: Pics of your turbo setups? [Re: crankn101] #2539387
08/21/18 01:08 AM
08/21/18 01:08 AM
Nampa, Idaho
Nampa, Idaho
Well mines a street/strip car, 100% street legal will even race with full interior.
Re: Pics of your turbo setups? [Re: Moparmatts72] #2539394
08/21/18 01:29 AM
08/21/18 01:29 AM
CO
CO
How is the exhaust ran?
Re: Pics of your turbo setups? [Re: dvw] #2539414
08/21/18 02:47 AM
08/21/18 02:47 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Doug
What size turbo? What size bov?
Re: Pics of your turbo setups? [Re: crankn101] #2539451
08/21/18 08:44 AM
08/21/18 08:44 AM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
76mm compressor, 50mm bov, 60mm WG, 23psi of boost on e85.
Re: Pics of your turbo setups? [Re: crankn101] #2539499
08/21/18 11:34 AM
08/21/18 11:34 AM
Nampa, Idaho
Nampa, Idaho
Well you can see the down pipe'show they are ran and then under he brought it down to just forward of where a header collector would be so it lines up where you would normally run an exhaust. I'll find a picture. Okay here is the exhaust routing.
Re: Pics of your turbo setups? [Re: dizuster] #2539561
08/21/18 01:41 PM
08/21/18 01:41 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Thanks, next question,what brand of each? I'm assuming the wg is adjustable.
