Carter strip Mechanical pump
#2538166
08/18/18 03:59 PM
08/18/18 03:59 PM
Posts: 4,296 Chicago, IL
TonyS451
Chicago, IL
I'm sure this question has been asked 100 times before, but how fast have you gone with this old pump? And how much power can it support (in your experience)?
I run one in my Challenger with 3/8" factory line, sender and tank, and honestly I really like the simplicity of this fuel system. Havnt raced it yet, but ran it hard through the gears a few times and never noticed any fuel delivery issues. Its a 505 w approx 550hp, 4 speed and 3.55's. I plan to throw a few more horses at it this winter (maybe get it closer to 600)and I'm guessing I'll be pushing it at that point...
2 kids and a dog
Re: Carter strip Mechanical pump
[Re: TonyS451]
#2538169
08/18/18 04:11 PM
08/18/18 04:11 PM
Posts: 4,663 Wichita
GY3
Wichita
121mph, 3600 lbs. With 5/16 fuel line.
3/8 from pump to carb.
[Re: TonyS451]
#2538183
08/18/18 05:24 PM
08/18/18 05:24 PM
Posts: 89 sweden
carter
sweden
512 with unknown hp and 3860 lb. With 3/8" factory sender and fuel line and Carter M6903. It fell on its nos at finish line in 1/8. Now running a CV Product fuel pump
[Re: TonyS451]
#2538192
08/18/18 06:03 PM
08/18/18 06:03 PM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
Hyd. cam 440, Modern ported Stealth heads, 750 holley, stock 5/16 fuel line and stock tank, 3850lb 67 Belvedere. 11.23-123 With a 150 shot of nitrous. Carter pump fed both engine and plate, makes for a great street car.
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: TonyS451]
#2538210
08/18/18 07:16 PM
08/18/18 07:16 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
My D50 ran a best of 6.29 @ 108 in the 1/8 with the Carter mechanical pump and 3/8 fuel line and a AutoZone plastic fuel filter. Switched to a big MagnaFuel pump and -8 line and saw no improvement.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: GY3]
#2538470
08/19/18 11:06 AM
08/19/18 11:06 AM
TonyS451
Chicago, IL
3/8 from pump to carb. Cool!
2 kids and a dog
[Re: TonyS451]
#2538495
08/19/18 12:13 PM
08/19/18 12:13 PM
TonyS451
Chicago, IL
Moparbilly - cool car and nice set up. I wouldn't have guessed that pump would feed the nitrous too!
D-50 - that's moving for sure and I guess better safe then sorry when it comes to fuel delivery and your upgraded fuel system...But your before and after is a perfect example of the overinflated pump requirements that we often hear about.
2 kids and a dog
[Re: ahy]
#2538501
08/19/18 12:21 PM
08/19/18 12:21 PM
TonyS451
Chicago, IL
Type of fuel, temperature and usage are big variables.
An engine compartment mounted pump sucks the fuel from the back. If the fuel gets hot and boils, pump capacity does not matter. It won't pump anything useful sucking vapor.
Current pump gas is made for EFI systems and boils easily.
A suitable electric pump mounted in the rear where it is cooler often works much better vs engine mounted pump. It gets some pressure in the fuel before it gets into the hot engine compartment. That would be my suggestion. Good points, and I'm definitely not opposed to electric pumps. My car also has a fuel filter with a 5/16 return line to prevent vapor lock. At least that what the claim is. I havnt had any hard starting issues when hot, so could be working.
2 kids and a dog
[Re: TonyS451]
#2538520
08/19/18 01:02 PM
08/19/18 01:02 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
.But your before and after is a perfect example of the overinflated pump requirements that we often hear about. My before and after. purple cam 440, inconsistent 10.80,s and .90,s with the carter pump, switched to a electric pump, 10.40,s no other changes.
[Re: Sport440]
#2538531
08/19/18 01:29 PM
08/19/18 01:29 PM
TonyS451
Chicago, IL
.But your before and after is a perfect example of the overinflated pump requirements that we often hear about. My before and after. purple cam 440, inconsistent 10.80,s and .90,s with the carter pump, switched to a electric pump, 10.40,s no other changes. Apparently that carter pump and/or system wasn't working for you. Were you experiencing stumbles? Also just curious, was it just the pump that you replaced, or were there other system items switched out as well?
2 kids and a dog
[Re: TonyS451]
#2538539
08/19/18 01:37 PM
08/19/18 01:37 PM
Sport440
Canton, Ohio
Yes with the carter strip pump I was experiencing some nosing over at the top end. When it would nose over it would run 10.9,s. When it didn't nose over, still felt like it was pulling, 10.8,s. Figured I would up grade to stop the nose overs at the top end figuring I could get Consistant 10,8,s. Well ended up getting consistant 10.47/10.50,s
Wow, wasn't expecting that, sometimes you can be starving for fuel and you Wont even know it. And yes Pump change only, nothing else. Thought I was just having some occasional fuel starvation nose overs.
[Re: Cab_Burge]
#2538548
08/19/18 02:14 PM
08/19/18 02:14 PM
TonyS451
Chicago, IL
The best test I know of for fuel system is to keep jetting the carb. up until it slows down in the 1/4 mile, if it won't you don't have enough fuel supply On my old pump gas Duster I had to go to .120 needles and seats to be able to jet it rich enough to slow that car down in he 1/4 mile Thanks Cab, that's great info.
2 kids and a dog
[Re: Sport440]
#2538550
08/19/18 02:17 PM
08/19/18 02:17 PM
TonyS451
Chicago, IL
Wow, wasn't expecting that, sometimes you can be starving for fuel and you Wont even know it. And yes Pump change only, nothing else. Thought I was just having some occasional fuel starvation nose overs. You must have been thrilled with that improvement! Thanks for the info.
2 kids and a dog
[Re: ahy]
#2538853
08/20/18 05:13 AM
08/20/18 05:13 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
A suitable electric pump mounted in the rear where it is cooler often works much better vs engine mounted pump. It gets some pressure in the fuel before it gets into the hot engine compartment. That would be my suggestion. I agree with this. I know many guys run the mechanical Carter pump but I run the Holley black pump mounted right by my fuel tank. I use a 3/8 stock type sending unit and run 3/8 line. Just the fact to have the fuel coming up to the front under pressure rather then being pulled under vacuum will help fight vapor lock a lot, The one problem I see is fuel boiling in the carb which can happen with either mech or electric pump. I like having my electric pump mounted by the gas tank so my fuel is under some pressure coming forward. But that's just me as many do still like to run the mechanical pump. Good luck with which ever setup you use. Ron
[Re: TonyS451]
#2538894
08/20/18 10:15 AM
08/20/18 10:15 AM
TonyS451
Chicago, IL
Thanks Ron - I'll be honest, if I thought I would race on a fairly regular basis, I would have an electric pump back there for sure. My car is really not set up for racing, but hopefully at some point I throw some sticky tires on and see what it can do. Or in my case w the 4 speed, see what I can do! I do smile when I hear about the guys running 10's with 5/16 line and mech pump, but I understand why that's not going to work for everyone.
2 kids and a dog
[Re: TonyS451]
#2538945
08/20/18 11:51 AM
08/20/18 11:51 AM
GY3
Wichita
Running 91 No Ethanol fuel and having a 1/2" phenolic spacer under the carb help with summertime issues.
[Re: TonyS451]
#2538955
08/20/18 12:02 PM
08/20/18 12:02 PM
Posts: 13,351 Marion, South Carolina [><]
an8sec70cuda
11.40 at 117.4 mph at 3700 lbs all motor. Carter strip mechanical pump w/ 3/8" line. 10.60s on a 150 shot, but the nitrous had a separate fuel system w/ an electric pump. Motor still fed by the mechanical Carter.
Later on I changed to -8 line w/ a Holley blue pump and put a sump in the tank. Ran no different.
