69 a-body tires #2536567
08/15/18 02:11 AM
08/15/18 02:11 AM
fredericksburg,va
cudaman1969 Online sleepy OP
cudaman1969  Online Sleepy OP
fredericksburg,va
My build sheet says T74 = E70x14 WSW Fiberglass. What brand and what size white stripe
Re: 69 a-body tires [Re: cudaman1969] #2536570
08/15/18 02:31 AM
08/15/18 02:31 AM
USA
big-block-dave Offline
USA
My 21k mile MODTOP survivor came with T72 E70x14 Firestone wide oval white streaks
I'm thinking The fiberglass are the Goodyears?
First link you can see the never used original spare, 2nd link is window sticker showing T72.
I'll look into T74 more, i have a NOS set(4)of Goodyears, but i think they say polyglass on them? The white stripe would be the thin one like my spare.(same size as RED stripe)
http://www.mooresmopars.com/modtop29.html
http://www.mooresmopars.com/images/jpg/modtop-on-ebay-original-window-sticker-modifieda.jpg
I'm the CARETAKER of Weinstats '69 440 'cuda registry and have 104 of the 360 cars to date. 84 fastbacks/20 coupes. Always looking for new(REAL M-code) '69 440 'cudas to add to the registry so drop me a note if any are found or known. This isn't a publicly released registry. Thanks, Dave
Re: 69 a-body tires [Re: big-block-dave] #2536577
08/15/18 02:54 AM
08/15/18 02:54 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
iagree
for '69 a-body 70 series tires
polyester cord = Firestone
fiberglass-belted = Goodyear
I don't think Firestone had a fiberglass 60 or 70 series tire available as OE for any manufacturer until the '70 model year
the 70 series tires had a stripe from 5/16" to 3/8"
Re: 69 a-body tires [Re: big-block-dave] #2537366
08/16/18 08:45 PM
08/16/18 08:45 PM
fredericksburg,va
fredericksburg,va
Find anymore info?
Re: 69 a-body tires [Re: cudaman1969] #2537811
08/17/18 07:25 PM
08/17/18 07:25 PM
FL
moparwizard Offline
moparwizard  Offline
FL
This is what I have for a 1970 T74 tire not sure if its the same for 69.
20180817_164456 resize.jpg20180817_164533 resize.jpg20180817_164544 resize.jpg
Re: 69 a-body tires [Re: cudaman1969] #2537961
08/18/18 12:55 AM
08/18/18 12:55 AM
fredericksburg,va
fredericksburg,va
Thanks that's perfect, my mag article says between 1962-83 for T74. Now to find a repop.
Dave, are these the same as yours?
Re: 69 a-body tires [Re: cudaman1969] #2537997
08/18/18 03:02 AM
08/18/18 03:02 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
it is the same tire for 1969,
is that spare from a '70 Windsor built 340 car?
AY = manufacturing date = 20th week of 1970 (mid-May)
NL = manufacturing plant = Toronto Goodyear plant
here is the website of the manufacturer of reproduction Goodyear tires: KELSEY TIRE up
http://www.kelseytire.com/pages/preformancetires2.html
it looks like F70-14s & G70-14s are available in "white streak", but they show RWL & "red streak" ONLY for E70-14, sounds like it's worth a call callme
Re: 69 a-body tires [Re: 6bblgt] #2538087
08/18/18 12:37 PM
08/18/18 12:37 PM
FL
moparwizard Offline
moparwizard  Offline
FL
[quote=6bblgt]it is the same tire for 1969,
Yes,you are correct it is a Windsor built 340 Dart.
Re: 69 a-body tires [Re: cudaman1969] #2538211
08/18/18 07:26 PM
08/18/18 07:26 PM
Ohio
carteravs Offline
carteravs  Offline
Ohio
My '69 Swinger 340 window sticker shows T74 E70x14 WSW tires,and came with
E70x14 Firestone Suprbelt red stripe bias belted polyester cord tires with fiberglass belts. The Firestone Wide Ovals that came out in '67 would squirm them- selves into oblivion in 10,000 miles or less,(usually less). My Suprbelts were pretty much used up in 40,000.
Re: 69 a-body tires [Re: cudaman1969] #2538422
08/19/18 02:46 AM
08/19/18 02:46 AM
USA
USA
pic
Re: 69 a-body tires [Re: cudaman1969] #2538423
08/19/18 02:47 AM
08/19/18 02:47 AM
USA
USA
pic2
Re: 69 a-body tires [Re: carteravs] #2538432
08/19/18 03:20 AM
08/19/18 03:20 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
if I understand correctly,
window sticker shows T74 E70-14 WSW "white streak" fiberglass belted tires
but had a set of T75 E70-14 RSW "red streak" fiberglass belted tires (& these were Firestone SUP-R-BELT)
did you order the car or was it on a dealer's lot?
how many miles when you got it?
when did you get the Swinger?
were all 5 the same tire?
Re: 69 a-body tires [Re: big-block-dave] #2538505
08/19/18 12:28 PM
08/19/18 12:28 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Didn’t they switch to Goodyear in 69. My 68had the Firestone Redlines.
Abe Lincoln
Re: 69 a-body tires [Re: dart4forte] #2538518
08/19/18 01:01 PM
08/19/18 01:01 PM
BlueRacer69 Offline
BlueRacer69  Offline
No. No switch in 69. My 69 Dart had Firestone E70-14 Redlines.
Re: 69 a-body tires [Re: 6bblgt] #2538581
08/19/18 04:05 PM
08/19/18 04:05 PM
Ohio
carteravs Offline
carteravs  Offline
Ohio
To answer your questions:(1) Correct, Tires were shown as T74 (all five), but were red stripe, which is what I ordered. (2) Mileage 6 IIRC. (3) I took delivery on 1/27/69 (after a 9 week wait). (4) Yes. Couple of other things
Dealers '69 Data Book under tires, notation"E", E70 in red or white. Fiberglass belted tires optional at extra cost. $71.80. The Broadcast sheet for my M code car shows tires as T73
Re: 69 a-body tires [Re: big-block-dave] #2538661
08/19/18 08:19 PM
08/19/18 08:19 PM
fredericksburg,va
fredericksburg,va
pic2
You got a pm
Re: 69 a-body tires [Re: carteravs] #2539221
08/20/18 07:53 PM
08/20/18 07:53 PM
blewbyu Offline
blewbyu  Offline
My M Code is also code T73 so what is correct for the T73 code?
Re: 69 a-body tires [Re: blewbyu] #2539317
08/20/18 11:08 PM
08/20/18 11:08 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
T73 is the STANDARD 1969 Dart GTS tire: E70-14 "red streak" polyester cord
most probably a Firestone Wide Oval Deluxe Champion
this is the tire that only managed ~10,000 miles before they were junk as "carteravs" tells in his story. up
scope I have notes that this E70-14 tire is from a Dart, but I don't know what year blush
Re: 69 a-body tires [Re: cudaman1969] #2539416
08/21/18 02:53 AM
08/21/18 02:53 AM
fredericksburg,va
fredericksburg,va
Is it possible that my build sheet shows T74 but came with red streak tires being an M-code?
Re: 69 a-body tires [Re: cudaman1969] #2539591
08/21/18 02:28 PM
08/21/18 02:28 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
it looks like for 1969:
Barracuda offered both the T74 E70-14 "white streak" fiberglass-belted & T75 E70-14 "red streak" fiberglass-belted tires
Dart offered only the T74 E70-14 "white streak" fiberglass-belted tire
shruggy
anyone have anything that shows T75 available on Dart, maybe late in the year??
"carteravs" did your Swinger come from a stand alone Dodge dealership or a Chrysler/Plymouth/Dodge dealer
