need help with 11" rear drum brakes #2537545
08/17/18 10:30 AM
08/17/18 10:30 AM
G code Jockey Offline OP
i recently aquired a 8 3/4 rear axle to go into a project dakota. it came with a set of 11 inch backing plates that i want to use. i just recently found out there are multiple widths of 11 inch brakes. how can i find out what width shoes/drums these plates need? i also see that rockauto has alot of the brake parts, but where can i get the non-wear items like the parking brake lever and cross bar? thanks for the info.
Re: need help with 11" rear drum brakes [Re: G code Jockey] #2537570
08/17/18 11:43 AM
08/17/18 11:43 AM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
I've never seen the cross bar as an aftermarket item but that doesn't mean they're not out there somewhere...
I know I have a few used ones...
The parking brake lever I have seen at different times in the "Help section" items... They make left and right hand arms...
I've always left complete 11" brake assemblies together (Drums and complete backing plates) just to make it easier for the next guy to know what he needs to order.
I have a couple of sets laying around...If you can get pics and dimensions from the axle flange to the flange where the brake shoes set I may be able to help...
...FAFO...
Re: need help with 11" rear drum brakes [Re: skicker] #2537589
08/17/18 12:19 PM
08/17/18 12:19 PM
moparx Offline
moparx  Offline
Megaparts has the cross bar and levers you need. they have lots of e-brake parts and hardware. hope this helps.
beer
Re: need help with 11" rear drum brakes [Re: moparx] #2537637
08/17/18 02:01 PM
08/17/18 02:01 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
https://www.forabodiesonly.com/mopar/thr...-brakes.413993/
I have parking brake levers and struts, for 11 inch brakes, for your consideration.
FYI
Do a search over at forabodiesonly for how to tell the differences in backing plate width sizes.
A member routinely posts pictures and measurements in how to tell them apart.
You just have to find the replies.
I never bookmarked something like that.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: need help with 11" rear drum brakes [Re: G code Jockey] #2537647
08/17/18 02:22 PM
08/17/18 02:22 PM
SW CO
HemiSportFury Offline
SW CO
Pretty easy to tell by measuring the height of the pin the the top of the shoes rest against. Allowing for the thickness of the brake shoe, that dimension if half of the width of the shoe. Pretty easy to tell a 3", 2"1/2 and 2" apart. Measure from the flat the shoe rests against (where you are supposed to put a dab of grease).
'64 Sport Fury, 528 Hemi, FiTech EFI, 4-speed, 4.10 Dana 60
'57 Belvedere 2dr sedan, current project in process
'19 Cherokee Trail Hawk Elite
'03 Ram 2500 CTD HO, 6-speed 214,000 miles and still going strong
Re: need help with 11" rear drum brakes [Re: G code Jockey] #2537655
08/17/18 02:34 PM
08/17/18 02:34 PM
BDW Offline
BDW  Offline
Re: need help with 11" rear drum brakes [Re: G code Jockey] #2537828
08/17/18 08:01 PM
08/17/18 08:01 PM
thanks guys for all the great info. according to the article i have a set of 2 1/2" plates, and yes i checked both of them. now time to search for parts.
Re: need help with 11" rear drum brakes [Re: G code Jockey] #2537866
08/17/18 09:26 PM
08/17/18 09:26 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
All the 80's cop car Diplomats are 11x2.5.
Might be easier to find one of those in a yard. Get the levers you need and the rest new. Rockauto has everything but the levers/struts
Don't be the exception.
Re: need help with 11" rear drum brakes [Re: Supercuda] #2537962
08/18/18 01:02 AM
08/18/18 01:02 AM
^^^ good plan
Re: need help with 11" rear drum brakes [Re: Supercuda] #2538115
08/18/18 01:23 PM
08/18/18 01:23 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
Noooooo. Save the Diplomat smile
Facts are stubborn things.
