Need LA Small Block Bolt Lengths - Available info? #2532536
08/06/18 10:18 PM
08/06/18 10:18 PM
Texas
GoodysGotaCuda Offline OP
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I am trying to get some hardware on hand before tearing into my 360.
Seeking bolt sizes [and qty] for the water pump, timing cover, valve covers, intake, exhaust manifolds, and any other applicable "external" fasteners.
Anyone have that info around that they could share?
Thanks!
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Need LA Small Block Bolt Lengths - Available info? [Re: GoodysGotaCuda] #2532561
08/06/18 11:08 PM
08/06/18 11:08 PM
Houston
I
it's Bob Offline
it's Bob  Offline
I
Houston
Does the ARP kit list the sizes? Might want to look there?
Re: Need LA Small Block Bolt Lengths - Available info? [Re: GoodysGotaCuda] #2532658
08/07/18 07:25 AM
08/07/18 07:25 AM
Akron, ohio
76orangewagon Offline
Akron, ohio
AMK Products sells a complete engine fastener kit with all the bolts you need, I also have seen individual kits on eBay for individual components like water pump bolt kits.
Re: Need LA Small Block Bolt Lengths - Available info? [Re: GoodysGotaCuda] #2533384
08/08/18 05:43 PM
08/08/18 05:43 PM
scratchnfotraction Offline
hey goody, I have a bolt bin with lots of stock engine bolts and smaller stock bolts if you want to replace with OEM bolts correct length.
lots of different length wp bolts depending on what accessory & yr
pulleys/damper/mounts/pan/alt/intake/valve cover/exhaust manifolds/ps pump & brackets/TC/flex plate/prop shaft bolts & straps ect..
need a 360 flywheel or any trans bolts? oil pans t-covers?
all free you cover shipping.
I can measure all the wp bolts I have for lengths. this is how I swap engines around and scratch up correct bolts going from a/c to non a/c or /6 to v8
Re: Need LA Small Block Bolt Lengths - Available info? [Re: GoodysGotaCuda] #2533554
08/09/18 12:25 AM
08/09/18 12:25 AM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Thanks for the offer, I have all the hardware, it's just in the engine currently. I will likely go ahead and just pull it, measure it and get new instead of trying to have new on-hand already.
2020 RAM 1500
Re: Need LA Small Block Bolt Lengths - Available info? [Re: GoodysGotaCuda] #2535256
08/12/18 08:12 PM
08/12/18 08:12 PM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
There is one bolt for the water pump on the left side that can't be too long or it can bottom out on number 1 outer cylinder wall and possibly push it in
Re: Need LA Small Block Bolt Lengths - Available info? [Re: 500ciDuster] #2537383
08/16/18 09:13 PM
08/16/18 09:13 PM
FYI block front pump/tcover bolt holes: Dr side top to bottom: (1) dry (2) wet (3) wet & #1 cyl wall is only 5/8" in from the block face (4) dry. Pass side top to bottom: (1) wet into valley (oil) (2) wet (coolant) (3) wet (coolant) (4) dry. Cam plate holes: (1) lower two are into crank area (2) dr top is blind (3) pass top into valley (oil) & that is the hole you want the OE bolt with the 1/8" hole in it for a drip or drill your own bolt. Others will clarify but iirc you want 1&1/4 times (1&1/2 times?) the bolt dia, that amt of thread engagement into the female block threads.
Re: Need LA Small Block Bolt Lengths - Available info? [Re: GoodysGotaCuda] #2537532
08/17/18 09:43 AM
08/17/18 09:43 AM
Georgetown de usa
E
Eggman Offline
Eggman  Offline
E
Georgetown de usa
I bought a kit from Roguue Bolt on ebay. Comes with everything.
