W5 heads leaking water in cylinder #2537423
08/16/18 11:28 PM
08/16/18 11:28 PM
Kentucky
71blackdemon Offline OP
Kentucky
My W5 heads have one cylinder that is getting water in it I had them sealed up before I put them on and I keep sealer in it what is the best sealer to put in the radiator to keep it from leaking also I'm looking to run a set of the Edelbrock Victor heads I'm hearing they will make more horsepower than the W5 what's your opinion
Re: W5 heads leaking water in cylinder [Re: 71blackdemon] #2537441
08/17/18 12:17 AM
08/17/18 12:17 AM
y W5 heads have one cylinder that is getting water in it I had them sealed up before I put them on and I keep sealer in it.
More info needed on what is going on/what has been done.
Re: W5 heads leaking water in cylinder [Re: RapidRobert] #2537471
08/17/18 01:32 AM
08/17/18 01:32 AM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Supposedly a common W5 issue from what I have read. Never owned a set though....
Repost this question in the race only section to reach a larger number of guys who might be able to help you.
Re: W5 heads leaking water in cylinder [Re: 71blackdemon] #2537687
08/17/18 03:27 PM
08/17/18 03:27 PM
Washington
madscientist Offline
Washington
You need to pressure test them and see where the leak is. I seen them leak from several places.
Everything is repairable. But just because you can doesn't mean you should.
