dist. drive gear depth issue.
#2537309
08/16/18 06:42 PM
08/16/18 06:42 PM
Posts: 1,899 MYRTLE BEACH SOUTH CAROLINA
ek3
I have a 440 -6 engine with orig dual point dist. measures 3.90" from base to shaft tip @ bottom. it is only sitting about .080 " in the gear slot . there is around .300" in the gear . Is there any way to get that down in there to say .200" or so? it shows signs of riding on the edge of the shaft. I put in a new BRASS bushing . could that be in to far ? I don't see any room to drop it with dist. shims . if it is the shim , can I change that out without disassembly ?
Re: dist. drive gear depth issue.
[Re: ek3]
#2537365
08/16/18 08:45 PM
08/16/18 08:45 PM
RapidRobert
4" is the std RB shaft length. You might weld/drill/tap the top of the intergear to add some material for the notch to engage. EDIT I just measured & it is 4&1/8"
[Re: RapidRobert]
#2537385
08/16/18 09:26 PM
08/16/18 09:26 PM
Posts: 10,697 North Dakota
6PakBee
North Dakota
Distributor original to engine? Take a look at the wear pattern on the end of the distributor shaft tang. How far in was it running? But as to your problem, it sounds like either the bushing in the block is too far in, the machined surface in the block that controls the height of the bushing is too low, or the gear is defective.
I am assuming you don't have a SB dual point that measures about 3.875".
[Re: lewtot184]
#2537414
08/16/18 10:59 PM
08/16/18 10:59 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
if the gear on the intermediate shaft isn't pinned it can be pressed a little further down the shaft effectively raising the slot. Not how that works. The gears are helically cut. This pushes the gear in one direction. Guess which way that is? Into the block where the bushing is. All messing with this is going to do is put the shaft deeper into the oil pump it won;t effectively raise the slot.
[Re: lewtot184]
#2537598
08/17/18 12:56 PM
08/17/18 12:56 PM
6PakBee
North Dakota
you guys need to get your thinking caps on. the gears position is fixed in relation to the block and i'm not talking about moving the shaft/gear relationship a couple feet. use your gray matter,...if you have any. A bit brusque but accurate. Yes, the oil pump shaft engagement would decrease at the expense of increasing the distributor shaft engagement. The position of the gear remains fixed. What bothers me about situations like this is that out of the millions of B and RB made, why would this be necessary on this particular motor and none of the others? Moving the shaft would work but is this masking a more serious problem? Is this just a band-aid for something else?
[Re: 6PakBee]
#2537665
08/17/18 02:50 PM
08/17/18 02:50 PM
RapidRobert
I just measured my RB points dist & it is 4&1/8 not 4" like I posted earlier. For you to run the dual points & see how it performed (I hear they weren't no slouch back in the day) & it would be interesting, I wonder if you could pirate a lower shaft from a single points dist to get this resolved???
[Re: RapidRobert]
#2537677
08/17/18 03:08 PM
08/17/18 03:08 PM
Posts: 25,728 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The RB shaft length is 4.00", the B shaft is 3.50".
The LA is 3.875" so the OP probably has a SB distributor.
[Re: ek3]
#2538348
08/19/18 12:40 AM
08/19/18 12:40 AM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
thanks everyone ! I will figure it out .. I can tell you why this one is different from all the millions of them - its my luck - !! really glad for all the input . sometimes you really scratch your head over this stuff....at least I found it before it was two problems ! And what was it?
[Re: ek3]
#2539400
08/21/18 01:40 AM
08/21/18 01:40 AM
RapidRobert
^^^ that's good to hear. I think you needed some good news!
