Re: Recommended Electronic Fuel Pump? - w/o Regulator
[Re: 71birdJ68]
#2537303
08/16/18 06:34 PM
08/16/18 06:34 PM
dogdays
This answer is so simple that folks disregard it. Carter P4070Internally regulated for street carburetor use. Simple to install, comes with mounting bracket and vibration dampers and fittings. Mine last for decades. https://www.summitracing.com/parts/CRT-P4070/Less than $100. R.
[Re: dogdays]
#2537469
08/17/18 01:30 AM
08/17/18 01:30 AM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
This answer is so simple that folks disregard it. Carter P4070Internally regulated for street carburetor use. Simple to install, comes with mounting bracket and vibration dampers and fittings. Mine last for decades. https://www.summitracing.com/parts/CRT-P4070/Less than $100. R. Ordered - I think that's what I am looking for. Thanks!
[Re: FurryStump]
#2537504
08/17/18 05:55 AM
08/17/18 05:55 AM
Posts: 2,806 Northern NJ
StukaJU87
Northern NJ
I run a carter mechanical and a holly red at the tank. Very stable fuel supply. Is the Holley just to prime the carb or does it run along with the Carter?
Scott
1969 Super Bee, 383/4 speed
[Re: StukaJU87]
#2537546
08/17/18 10:30 AM
08/17/18 10:30 AM
Posts: 2,807 Connecticut
FurryStump
Connecticut
I run a carter mechanical and a holly red at the tank. Very stable fuel supply. Is the Holley just to prime the carb or does it run along with the Carter? Run them both all the time. It will run with the electric off, but will not rev up over 4000 rpm. So if it dies you can get home, but no hard driving. I have run holley blue, holley black. Still had issues, i’m sure it was the cheap regulator. With this set up absolutely no issues.
[Re: FurryStump]
#2537737
08/17/18 05:29 PM
08/17/18 05:29 PM
StukaJU87
Northern NJ
I run a carter mechanical and a holly red at the tank. Very stable fuel supply. Is the Holley just to prime the carb or does it run along with the Carter? Run them both all the time. It will run with the electric off, but will not rev up over 4000 rpm. So if it dies you can get home, but no hard driving. I have run holley blue, holley black. Still had issues, i’m sure it was the cheap regulator. With this set up absolutely no issues. Thank you sir.
Scott
