Re: Basic 360 top end build w/exhaust manifolds - Power guesses?
[Re: GoodysGotaCuda]
#2537099
08/16/18 11:47 AM
08/16/18 11:47 AM
Posts: 1,754 Windsor, ON, Canada
Diplomat360
Windsor, ON, Canada
Well, that is not a particularly big cam, neither the lift nor the duration @ 0.050" are huge, but on the flip side that will make for a decent cruising setup...and that setup got you a 270 WHEEL hp? That is pretty good!
I would think in a 360 motor, all else being equal, that's an easy +40 hp all due to the extra cubes, but that would theoretically get you to about 300 wheel hp, which I think implies about 375-400 crank hp??? (someone help me out on this, my understanding is that it's typically 25% hp loss from crank to wheel)
However, if that 360 combo produces 400 crank hp, with that small of a cam, I would be surprised.
#2537117
08/16/18 12:34 PM
08/16/18 12:34 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
simply put, HP is airflow. Whatever the bottle neck in airflow is will determine the HP.
Is it the cam? the manifolds? the cylinder heads?
Hard to say since not all else will be equal but I think if you got 300 at the wheel I'd be happy. assuming the 270 whp number as accurate. I think you are likely to see more improvements in the torque numbers, which is what you really want on a driver.
#2537164
08/16/18 01:54 PM
08/16/18 01:54 PM
Posts: 4,404 Michigan
MarkZ
Worthy
Worthy
One of the magazines did a shootout a number of years ago dyno testing various manifolds and header combinations on a 300 HP 360 Magnum crate motor. Differences were negligible between long tubes and manifolds at that level. I think there was 20 ft/lbs between worst and best. Anything much past that level and you'll start seeing restrictions get progressively worse. Edit: Found it... https://www.hotrod.com/articles/mopp-0307-mopar-crate-engine-exhaust/ Results are in the picture captions.
#2537177
08/16/18 02:16 PM
08/16/18 02:16 PM
Posts: 14,492 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Probably a 25-35hp gain with headers.
On a combo like that, full length headers are really hard to beat from a $$/hp standpoint.
[Re: fast68plymouth]
#2537213
08/16/18 03:25 PM
08/16/18 03:25 PM
Supercuda
About to go away
About to go away
up yours
Probably 25-35hp
On a combo like that, full length headers are really hard to beat from a $$/hp standpoint. Actually, it's real easy to beat both in money and hp. From the aforementioned HotRod article
#2537284
08/16/18 05:25 PM
08/16/18 05:25 PM
fast68plymouth
So. Burlington, Vt.
I guess if we’re going to quote magazine articles....... Stock 340 with stock 210/220-114lsa cam: The advantage of individual full-length tubes was clear with the next run of the dyno-330.4hp at 5500 rpm, and 369.1 lbs/ft at 3900 rpm. The torque curve was up substantially from the bottom rpm of our pulls, right up to and past redline. The headers added power everywhere, meaning a harder launch and harder pulling up top. In fact, the peak power output on the rpm band increased by 300 rpm, while the torque peak dropped by 100 rpm, the result of an all-around fatter torque curve and a race-winning extended powerband. Bottom line? Headers work. And then last year in Mopar Muscle, another stock 340: On factory claims of 275 horsepower at 5,500 rpm and 340 lb-ft (3,200 rpm), we got 320 horsepower at 5,500 rpm and 368 lb-ft at 3,500 rpm. So it’s clear Mopar understated the facts by 45 horsepower and 28 lb-ft. Then we replaced the manifolds with a set of headers and got 352.1 horsepower and 395.9 lb-ft (at 3,200 rpm)—77.1 horsepower and 55.9 lb-ft higher than published peak claims. That’s 32hp & 27ft/lbs over manifolds. And: https://www.google.com/amp/s/www.hotrod.com/articles/comparing-headers-and-manifolds/amp/I’m sure you could find endless examples on the internet to “prove” either side of the argument. I’ll go with what I’ve experienced....... Motors with bigger, better flowing heads, combined with longer duration cams that utilize tighter lsa’s benefit more from headers than motors with stock heads and stock cams. Like this: https://www.google.com/amp/s/www.hotrod.com/articles/mopp-0106-manifolds-vs-headers/amp/
#2537307
08/16/18 06:41 PM
08/16/18 06:41 PM
Supercuda
About to go away
About to go away
up yours
And what is the OP building?
A very mild combo that really isn't much different than the crate motor used in the test. He sure is NOT building anything hipo.
Now, I am sure if someone wanted to donate to the OP a set of TTi's then he'd probably consider it. Doesn't need them though.
#2537312
08/16/18 06:49 PM
08/16/18 06:49 PM
Posts: 4,310 Prospect, PA
BSB67
Prospect, PA
This is why I will no longer try to answer..."how much more, or how much less" question regarding manifolds. And that does not even factor into all the BS dyno stuff and magazine articles. Simply pick a HP goal and match the cam to the exhaust system to be used. 300 HP, no problem. Just use the right cam. Any well thought out engine will easily make 1 HP/cu.in with manifolds.
#2537319
08/16/18 06:58 PM
08/16/18 06:58 PM
fast68plymouth
So. Burlington, Vt.
In the first link I posted the motor is very close to what the OP is building(low cr 360 with an intake and a mild hyd cam).......still gained 17ft/lbs and 33hp from a set of under $200 headers. Seems like a pretty nice bang for the buck to me. That article written by a Moparts member too 👍 The cam specs in my 2001 catalog for the 300hp crate motor are 250/264 advertised duration, .385/.410 lift. Quite a bit smaller than the OP’s cam. The noticeable increase in duration and overlap, along with the heads having bigger intake valves than the 300hp crate are going play into the headers showing more gains over manifolds than what was seen in that magnum motor. Will it still run okay with manifolds? Of course. But to think you’re only leaving like 8-10hp on the table with that build isn’t realistic. Actually, it's real easy to beat both in money and hp. Even on that 300hp crate with the tiny cam, all of the headers beat all the manifolds.
