What ECU should I carry as spare? '79 Power Wagon
#2536359
08/14/18 07:41 PM
08/14/18 07:41 PM
Posts: 15,806 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I have a little breakdown kit with extra parts, such as Ballast Resistor, Starter Relay, Fan Belt, etc. I want to add an Electronic Ignition Box to kit. It's a factory 360-4. What would be the most reliable box to purchase to keep or maybe even install now, and keep the old one as a spare. I know it's NOT the orange box. I have below style Ballast Resistor, which means I have five pin box, I think? I should have looked first I guess, but just haven't had a chance, and I know you guys know Just stretched the legs on the truck the most I have so far since buying well over a year ago now. 80 miles round trip, and it performed great! Really cruised nicely and I enjoyed it so much. Couldn't get rid of the smile on my face. I drove to pick up a used door for my Dad's car. Thanks. P.S. I don't mind spending a few bucks to get something quality.
Facts are stubborn things.
Re: What ECU should I carry as spare? '79 Power Wagon
[Re: larrymopar360]
#2536375
08/14/18 07:56 PM
08/14/18 07:56 PM
Posts: 20,622 in a cattle trailer down by th...
Guitar Jones
The 4 pin will work in place of the 5 pin. I would just buy a name brand like Standard, Borg Warner or the like if it's just an emergency box. Any of them should get you home.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: larrymopar360]
#2536404
08/14/18 08:45 PM
08/14/18 08:45 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Ok, thanks. I know it's an old story, but I just hate buying parts now with so much cheap junk coming from other countries. Some of this stuff is bad right out of the box.
[Re: larrymopar360]
#2536459
08/14/18 10:19 PM
08/14/18 10:19 PM
RapidRobert
What Guitar Jones said, get a 4 pinner at your parts house & unfortunately most of em are overseas made. (or an OE 5 pinner from a yard).
[Re: BcudaChris]
#2537422
08/16/18 11:21 PM
08/16/18 11:21 PM
Posts: 1,151 Cruising!
QuickDodge
Cruising!
What is FBO that BcudaChris mentions?
One Plymouth I had many years ago had ballast resistors go bad fairly often. I kept a spare on in that car. Never did get that problem diagnosed. The other Mopars I've owned never had any problems.
[Re: QuickDodge]
#2537445
08/17/18 12:29 AM
08/17/18 12:29 AM
RapidRobert
www.4secondsflat.com Just me I would forget that & go with an OE black '75 up HEI module from a yard & there is a alum plate from www.designed2drive.com to mount it under the dist (pricey & it is easy to make your own) & get a full 12V E coil (no ballast needed). use heat sink paste between the module & the plate. EDIT not the OE HEI here, this was a guys' extras he was unloading.
[Re: BcudaChris]
#2537662
08/17/18 02:41 PM
08/17/18 02:41 PM
RapidRobert
I've used the FBO limiter plate several times, its a VG deal.
[Re: larrymopar360]
#2538202
08/18/18 06:38 PM
08/18/18 06:38 PM
Posts: 7,982 Scranton, PA
Montclaire
Scranton, PA
There was a thread a while back with a number of different ECUs gutted - I can't remember where I saw it. One box was a chinese deal with a postage stamp sized circuit board and a simulated heat sink. I'd love to see a full comparison done on all available stock boxes. I don't think Mopar Action has done an article on them but I stopped reading for a couple years so I could be wrong.
[Re: larrymopar360]
#2538261
08/18/18 10:08 PM
08/18/18 10:08 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Robert, I know that is probably the best thing, an HEI setup, but I just really want the Ma Mopar look to remain. I was so hesitant on even going with headers, but I broke down and did it when I had to do the entire exhaust anyhow. I probably should have gotten the headers coated black. The Rev-n-ator is a really cool system for reliability and sort of stock appearance, but too pricey for this stock engine truck. I have that on my stroked small block Diplomat and love it.
[Re: larrymopar360]
#2538302
08/18/18 11:35 PM
08/18/18 11:35 PM
RapidRobert
Understood, I would just grab a spare. On a side note the $25 plate is a real good tuning piece.
[Re: Montclaire]
#2539570
08/21/18 01:52 PM
08/21/18 01:52 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I just bought it yesterday from R. Ehrenberg along with a coil! Decided it sounded like a good reliable piece and stock appearing enough if I pull off the high rev sticker. Thanks.
