Re: 2001 V-10 transmission ?
[Re: moparx]
#2536275
08/14/18 05:14 PM
08/14/18 05:14 PM
Posts: 125 kalispell montana
jwilson 61
kalispell montana
it is a 47re trans , so it depends on inputs from governor sensor and tps and speed sensor and others to determine shift strategy, so yes it does need a tcm to control it, Im sure someone has developed something I just don't know who
70 cuda 440 6bbl Auto with a dana 60 68 road runner QQ1 383 auto 1970 6 barrel 4 speed Superbird FY1 number matching 15 Challenger 6.4 SRT pearl White 6 Speed 72 Cuda 440 5 speed 71 Road Runner 440 4 speed
[Re: moparx]
#2536349
08/14/18 07:22 PM
08/14/18 07:22 PM
Posts: 25,743 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The TFOD-3 is a manual shift conversion and therefore bypasses the governor and speed sensor control but still needs electrical input for OD and lockup.
[Re: moparx]
#2536434
08/14/18 09:46 PM
08/14/18 09:46 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Are you planing on using it behind a v10? The bell housing wont fit a v8 if that is the plan.
[Re: moparx]
#2536605
08/15/18 09:09 AM
08/15/18 09:09 AM
Posts: 20,626 in a cattle trailer down by th...
Guitar Jones
CRT has full manual shift trans brake valve bodies for them. Manual control of 1st, 2nd, 3rd and O/D. You can have lockup too on a switch.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
