accelerator pump size?
#2535373
08/12/18 11:33 PM
08/12/18 11:33 PM
Posts: 574 Just South of The Motor City
limechallenger
I've got a 70 T/A Challenger with a original 340/6pack, I rarely drive it anymore , but I fired it up the other day and noticed the accelerator pump is leaking pretty bad! So it looks like I will pull the carbs ,anyway I need to know what size diaphragm it has ! E-bay has both 50 cc and 30 cc, anybody know which one I need? Thanks!
70 T/A Challenger
78 Aspen R/T
87 Indy 500 Dakota
Re: accelerator pump size?
[Re: limechallenger]
#2535376
08/12/18 11:39 PM
08/12/18 11:39 PM
Posts: 15,547 Norwich CT USA
moparts
Norwich CT USA
From pictures I see on line it is the small Accelerator pump
Tom ,
2011 Ram 3500 C&C Diesel 2009 Challenger R/T 1971 Challenger Conv. 511/4 speed 1970 Challenger R/T 503/727
[Re: Cab_Burge]
#2535598
08/13/18 01:24 PM
08/13/18 01:24 PM
RapidRobert
Cab is the man! (& for your app I wouldn't think you'd need the extra squirt from 50CC's)
[Re: topside]
#2535637
08/13/18 02:38 PM
08/13/18 02:38 PM
RapidRobert
^^^ good info (& sand in a figure 8). EDIT with solvent & not sure what grit paper, 600?
[Re: lewtot184]
#2536099
08/14/18 12:01 PM
08/14/18 12:01 PM
limechallenger
center carb came with 30cc pump. may not be the pump but a poor seal between the metering block and carb body due to warpage. been thru it! is it gonna warp after 20 years? I built the car in 1992 and have never had a problem, just recently ,it's been a year since I last ran it and the leak developed!
70 T/A Challenger
78 Aspen R/T
87 Indy 500 Dakota
#2536167
08/14/18 02:12 PM
08/14/18 02:12 PM
Posts: 3,916 usa
lewtot184
usa
center carb came with 30cc pump. may not be the pump but a poor seal between the metering block and carb body due to warpage. been thru it! is it gonna warp after 20 years? I built the car in 1992 and have never had a problem, just recently ,it's been a year since I last ran it and the leak developed! what happens is the body gets distorted from repeated tightening of the float bowl screws. if your carb has had few rebuilds/jet changes/etc then maybe your ok. I know I've chased accelerator pump leaks only to find the weeping was between the metering block and carb body.
[Re: lewtot184]
#2536241
08/14/18 04:18 PM
08/14/18 04:18 PM
Posts: 43,097 Bend,OR USA
Cab_Burge
center carb came with 30cc pump. may not be the pump but a poor seal between the metering block and carb body due to warpage. been thru it! is it gonna warp after 20 years? I built the car in 1992 and have never had a problem, just recently ,it's been a year since I last ran it and the leak developed! what happens is the body gets distorted from repeated tightening of the float bowl screws. if your carb has had few rebuilds/jet changes/etc then maybe your ok. I know I've chased accelerator pump leaks only to find the weeping was between the metering block and carb body. Murphy loves messing with us hot rodders My message is many things, problems, can have the same results cause by several different things
