Clutch fan studs #2534383
08/10/18 09:41 PM
08/10/18 09:41 PM
Georgetown de usa
E
Eggman Offline OP
Eggman  Offline OP
E
Georgetown de usa
Does anyone know where i can get the studs and nuts for a clutch fan to mount to the water pump?
Re: Clutch fan studs [Re: Eggman] #2534404
08/10/18 11:23 PM
08/10/18 11:23 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
The fan attached to the clutch with 5/16" X 3/4" long bolts on my rides. Gene
Re: Clutch fan studs [Re: Eggman] #2534431
08/11/18 01:11 AM
08/11/18 01:11 AM
How about your local Dodge dealer or NAPA store? scope
Re: Clutch fan studs [Re: Eggman] #2534483
08/11/18 08:28 AM
08/11/18 08:28 AM
Guitar Jones Offline
Hardware store?
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: Clutch fan studs [Re: Eggman] #2534670
08/11/18 05:28 PM
08/11/18 05:28 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Carburetor studs.
Re: Clutch fan studs [Re: poorboy] #2534693
08/11/18 06:07 PM
08/11/18 06:07 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
Right. Just get some 5/16" x 3/4" bolts from hardware store. That's what they should use as poorboy wrote.
Facts are stubborn things.
Re: Clutch fan studs [Re: Eggman] #2534793
08/11/18 10:24 PM
08/11/18 10:24 PM
Georgetown de usa
E
Eggman Offline OP
Eggman  Offline OP
E
Georgetown de usa
I have the fan and clutch already together. I was referring to the fan to water pump.
Re: Clutch fan studs [Re: Eggman] #2534925
08/12/18 03:09 AM
08/12/18 03:09 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Clutch to water pump use the same 5/16" X 3/4" bolts. The Mopar bolts had the washers attached, but just the bolts work. If your clutch has the slotted openings rather then a round hole, just add the washers to the bolts. Gene
Re: Clutch fan studs [Re: Eggman] #2534956
08/12/18 09:34 AM
08/12/18 09:34 AM
Georgetown de usa
E
Eggman Offline OP
Eggman  Offline OP
E
Georgetown de usa
Thank you
Re: Clutch fan studs [Re: Eggman] #2535212
08/12/18 06:58 PM
08/12/18 06:58 PM
scratchnfotraction Offline
MOPAR used to have studs then went to bolts.
look in the Dorman fastener line for the clutch to wp studs or bolts.
I often grab a 7 blade fan from a GM engine to upgrade the mopar 5 blade fans when I cant find a 7 blade MOPAR fan.
Re: Clutch fan studs [Re: scratchnfotraction] #2538729
08/19/18 10:33 PM
08/19/18 10:33 PM
IN
ahy Offline
ahy  Offline
IN
On stock or "stockish" setups I run simple bolts. The original had captured semi bell shaped washers. I have also used common grade 5 or grade 8 bolts with small flat washer and lock washer and that works fine also.
If you have a spacer or other situation that wants studs, a good ACE hardware will have them.
