Re: What parts for your mopar would you like to see reproduced?
[Re: moparmadman69]
#2534327
08/10/18 06:41 PM
08/10/18 06:41 PM
Posts: 6,710 KY
65pacecar
KY
1965 Sport Fury (C Body) trunk Finish Panel, upper and lower Trunk Moldings.
1967 B Body (Plymouth and Dodge) Quarter panels (Full)
1965 Fury Quarter Panels (Full) or even quality Half/Patch.
[Re: moparmadman69]
#2534384
08/10/18 09:43 PM
08/10/18 09:43 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Just want to get some ideas on what isn't made currently for A/B/E body that is desperately needed. The hobby has come a long way as regards to parts availability but there are still some big holes out there. What "holes" are you looking to fill?, driveline, suspension, sheetmetal, potmetal, stainless /aluminum trim, wheels, interior, etc, etc, etc, etc, etc, etc, etc ???????????????????????????????
[Re: moparmadman69]
#2534401
08/10/18 11:16 PM
08/10/18 11:16 PM
Posts: 13,565 md
mopars4ever
md
So far none of the items listed will see the day of light, Hmmm.... Vans auto makes or sells a gas tank sending unit for the lowly 76-77 f body that wasn`t available just a few years ago. He has sold a good amount of them on ebay and elsewhere.
[Re: moparmadman69]
#2534441
08/11/18 01:36 AM
08/11/18 01:36 AM
Posts: 16,468 On the run…
BloFish
On the run…
1969 Plymouth Barracuda lower rocker molding and clips.
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: moparmadman69]
#2534443
08/11/18 01:45 AM
08/11/18 01:45 AM
Posts: 3,691 MO
cdp
MO
[Re: cdp]
#2534448
08/11/18 02:14 AM
08/11/18 02:14 AM
Posts: 20,453 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
Rubber/Vinyl floor mats. The OG translucent colored ones that you used to find in original cars years ago. Have not seen those in many years.
Pushbutton radio buttons. Chrome is always pitted or flaked.
Brake splash shields.
70-71 Dodge Challenger bumper guards. Someone on here was looking for those and turns out they are hard as hell to locate.
Radiator support to k-member brackets. Often full of gouge marks from hitting concrete curbs or wheel stops.
Brake rotor outer wheel bearing dust caps.
Correct chrome rallye wheel lug nuts.
Rallye wheel trim rings. Don't even think you can find 14" ones anymore, and clean 15x7 ones are worth stupid money now.
OEM style lower control arm sway bar brackets that can be welded to non-sway bar control arms. 67-72 a-body lower control arms with sway bar tabs are not cheap anymore.
Heater box housings would be cool, but doubt that would be cost effective. Many are dried out or cracked so it's getting hard to find nice ones if you building a high end car.
Mod tops and gator tops.
How about 904 and 727 oil pans? Maybe make them out of thicker metal too?
[Re: cdp]
#2534486
08/11/18 08:58 AM
08/11/18 08:58 AM
Posts: 892 MA
steve70
MA
Now available from Legendary
1970 Challenger T/A 4 speed
[Re: moparmadman69]
#2534586
08/11/18 02:22 PM
08/11/18 02:22 PM
Posts: 3,482 Cold Spring, NY
1970GTX
Cold Spring, NY
The following B body items:
66-70 convertible top header panel repair panels. 66-67 seat tracks 66-67 lower trunk repair panels Heat riser repair kits
