Page 1 of 3 1 2 3
New S60 for the Coronet #2533851
08/09/18 05:27 PM
08/09/18 05:27 PM
AndyF Offline OP
AndyF  Offline OP
I still have a few parts to round up for the swap but I'm getting closer. I've been using a factory '68 B body Dana 60 under my Coronet for the past 30 years. It has worked just fine but I figured it was time to step up to the newer stuff so I got together with DoctorDiff to order a new combo.
This one is narrowed just a small amount, has the billet pinion yoke, 3.23 gears, helical differential, Baer rotors and the Mustang calipers. I need to bend up the brake lines yet and then figure out the e brake setup. Hopefully everything else lines up properly so I can drop it back on the ground.
Re: New S60 for the Coronet [Re: AndyF] #2533853
08/09/18 05:34 PM
08/09/18 05:34 PM
Texas
RustyM Offline
RustyM  Offline
Texas
Sweet, You could drive cross country with that set up.
Re: New S60 for the Coronet [Re: AndyF] #2533871
08/09/18 06:04 PM
08/09/18 06:04 PM
an8sec70cuda Offline
Very nice. Are those 3.23 gears available from Strange??? Don't see them on their website or on Dr. Diff's.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: New S60 for the Coronet [Re: AndyF] #2533873
08/09/18 06:07 PM
08/09/18 06:07 PM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
Looks sweet. I want one!
2 kids and a dog
Re: New S60 for the Coronet [Re: an8sec70cuda] #2533875
08/09/18 06:12 PM
08/09/18 06:12 PM
AndyF Offline OP
AndyF  Offline OP
Doctor Diff has tooled up the 3.23 gears but they aren't available yet. I have the first prototype set in this rearend so I'm the guinea pig. If they whine and howl then it will be back to the drawing board. If they work great then he'll put them on the website and start taking orders. Might be another 3 or 4 months until they are available on the website.
Re: New S60 for the Coronet [Re: AndyF] #2533877
08/09/18 06:13 PM
08/09/18 06:13 PM
Awesome, thanks Andy.
CHIP
Re: New S60 for the Coronet [Re: RustyM] #2533878
08/09/18 06:14 PM
08/09/18 06:14 PM
AndyF Offline OP
AndyF  Offline OP
Yeah I'm working on making the car more of a driver than it has been. I have the Doug Nash 5 speed in it so the first four gears are roughly 4:1 and then 5th is the 3.23. So it pulls hard in the first four and then I can kick it into 5th for freeway cruising.
Re: New S60 for the Coronet [Re: AndyF] #2533883
08/09/18 06:17 PM
08/09/18 06:17 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
That looks like a nice stout piece for sure............ thumbs
Re: New S60 for the Coronet [Re: Thumperdart] #2533918
08/09/18 07:49 PM
08/09/18 07:49 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Very cool!
'63 Dodge 330
11.19 @ 121 mph
Re: New S60 for the Coronet [Re: GY3] #2533923
08/09/18 08:09 PM
08/09/18 08:09 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
The MoPig has a new Strange S60 under it now, but it's totally Plain Jane compared to the new one for the AndyMobile. whiney
Re: New S60 for the Coronet [Re: AndyF] #2534066
08/10/18 06:41 AM
08/10/18 06:41 AM
Deep DEEP SOUTH
LAD 524 Offline
LAD 524  Offline
Deep DEEP SOUTH
VEry kool Andy, keep us posted on those 3.23s.
Re: New S60 for the Coronet [Re: LAD 524] #2534113
08/10/18 11:41 AM
08/10/18 11:41 AM
Weatherford, Texas
RapidusMaximus Offline
Weatherford, Texas
Amen to that...a 3.23 in a Dana would keep me from switching to a 9" Ford in the little turbo Dakota up
1968 Plymouth GTX
1974 Dodge P/U Long Bed Stepside 318
2019 Ram 2500 6.4, auto, 4WD
Re: New S60 for the Coronet [Re: AndyF] #2534117
08/10/18 11:52 AM
08/10/18 11:52 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Any weight comparison to the original Dana 60?
Re: New S60 for the Coronet [Re: 451Mopar] #2534169
08/10/18 01:29 PM
08/10/18 01:29 PM
AndyF Offline OP
AndyF  Offline OP
I intend to weigh both but I don't have those numbers yet.
Re: New S60 for the Coronet [Re: AndyF] #2534187
08/10/18 02:14 PM
08/10/18 02:14 PM
fullmetaljacket Offline
My notes are not in front of me, but as far as aftermarket 60's go, the Strange unit that I ordered through Dr Diff was 2 lbs lighter than the Moser housing of the same size.
The factory units may be either heavier or lighter. If lighter, I would suspect that there aren't as many reinforcement welds on the axle tubes and or gussets like the new units have. Weld beads can add up the weight quite fast fellas. but I could be wrong.
Re: New S60 for the Coronet [Re: RapidusMaximus] #2534196
08/10/18 02:38 PM
08/10/18 02:38 PM
Cab_Burge Online work
Cab_Burge  Online Work
Do you know about the pick up truck Dana 61 with 3.30 and 3.07 gears in them?
I know of two in a local scrap yard that I should own now realcrazy
Time to act now instead of talking work
Re: New S60 for the Coronet [Re: AndyF] #2534276
08/10/18 04:46 PM
08/10/18 04:46 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Looks great buddy.
Also looks expensive, but I'm thinking a complete, real B body Dana with legible BOM numbers would probably pay you back most of the way for that nice looking new axle. It'd be really cool to break even and help out someone doing a resto at the same time.
Rich H.
Esse Quam Videri
Re: New S60 for the Coronet [Re: AndyF] #2534311
08/10/18 06:04 PM
08/10/18 06:04 PM
AndyF Offline OP
AndyF  Offline OP
The Dana 60 I have is really clean and good shape so I'm sure I'll be able to get a good price for it. I don't need a numbers correct Dana in my car so you're correct, sending it down the road to someone who needs one is a good thing to do.
Re: New S60 for the Coronet [Re: AndyF] #2534351
08/10/18 07:47 PM
08/10/18 07:47 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
210lbs!!
Re: New S60 for the Coronet [Re: AndyF] #2534414
08/10/18 11:55 PM
08/10/18 11:55 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
You might have just made his phone go crazy. popcorn
Page 1 of 3 1 2 3
