71 challenger tank vent #2534078
08/10/18 09:25 AM
08/10/18 09:25 AM
Sharpsburg Maryland
440farmer Offline OP
Sharpsburg Maryland
I have a question about the vent lines that go up inside of tube in the trunk
Why are 2 of them 3/8 and the rest 1/4 and 5/16
the tank tubes are all 1/4 and which goes where
I believe the 5/16 goes up to the valve cover but the others go to tank
Re: 71 challenger tank vent [Re: 440farmer] #2534204
08/10/18 02:52 PM
08/10/18 02:52 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
The four tank lines are connected straight to the pipe. The fifth line goes to the three nipple breather on your valve cover. The breather also connects to the carb bowl vent and the air cleaner
Re: 71 challenger tank vent [Re: 440farmer] #2534221
08/10/18 03:15 PM
08/10/18 03:15 PM
Sharpsburg Maryland
Sharpsburg Maryland
Yeah I got that but why is 2 of the tubes that goes into the neck 3/8 ?
and all nipples on the tank are 1/4 is/was there some check valves inline to/from tank??
I'll make it work but was askin the experts just what is what
