Re: New S60 for the Coronet
[Re: AndyF]
#2550528
09/16/18 03:39 AM
09/16/18 03:39 AM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
Looks good Andy that 3.23 should work perfect with the super low gear in the 5-speed. Mine has a 3.27 low gear and I had 4.56 gears in the rear when I first installed it. I never did the math but I was shifting right after the tree. If Cass ends up making a run of the 3.23 gears I'm sure he will sell all of them. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: dthemi]
#2552084
09/19/18 09:55 PM
09/19/18 09:55 PM
fourgearsavoy
Rittman Ohio
Side adjusters in a dana is just the best thing ever. You aren't kidding the last 2 gear sets I done are the old factory deal. Not bad with a spool but that Powerlock is freakin heavy changing shims. I haven't had the opportunity to change gears on the new S60. I should trade my 68 housing in on a Strange S60 Maybe with a set of 3.23 gears. Gus
[Re: AndyF]
#3002704
01/06/22 08:21 PM
01/06/22 08:21 PM
Posts: 11 So cal
EFI DART
So cal
Gday Andy, I love your book on Wedge engines I am building a 68' Dodge dart with all Mopar running gear this time, last time it was on the road it had a Furd 9" With the persuasion of a local buddy he's convinced mem into building a Dana S60 with all the fruit.
I seem to be having contact pattern issues where there appears to be too much contact on the heel & toe of of the ring gear set
If i shim out the pinion bearing it becomes too deep
If u reduce it becomes too shallow (see pics)..... unlike all other gears i have set up this will not give me a perfect oval shape in the centre of the drive side.
From what i can tell the gear sets are not ground as well as a Dana Spicer.
Cass Esslicks "Dr Diff" 3.23 gear set and
Any input is greatly appreciated
Moparaaaaaaars
[Re: Twostick]
#3104865
12/23/22 12:48 PM
12/23/22 12:48 PM
Posts: 30,992 Oregon
AndyF
I've been driving the car for four years now. No noise or any problems with the 3.23 gears.
[Re: AndyF]
#3105187
12/24/22 12:10 PM
12/24/22 12:10 PM
Posts: 6,560 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
I've been driving the car for four years now. No noise or any problems with the 3.23 gears. Are they in production? I don't see them on Dr Diff's site. Kevin
[Re: Twostick]
#3105312
12/24/22 06:53 PM
12/24/22 06:53 PM
Posts: 43,115 Bend,OR USA
Cab_Burge
I've been driving the car for four years now. No noise or any problems with the 3.23 gears. Are they in production? I don't see them on Dr Diff's site. Kevin Have you thought of changing the rear tires to a taller set like 6 or more inches in circumference (2 to 4 inches taller)? If not, maybe you look into that
