Order of assembly questions #2533783
08/09/18 02:50 PM
08/09/18 02:50 PM
Hazlet nj
Joemoy29 Offline OP
Joemoy29  Offline OP
Hazlet nj
Hello, I am getting my 72 cuda back from paint next week. This will be my first complete restoration. It may be a dumb question but is there a order every one does this. The suspension and dash/ headliner is already installed. I was thinking wiper motor/ engine bay harness. Drop the engine and trans in together (hood has to be off?) Is it easier to drop the k frame and put the engine and trans on that then lower the car to k frame?
Is the grill the last thing to go on? I am mainly looking to see if there are any tips and tricks from the masters who have done this a million times lol. Thanks in advance
Re: Order of assembly questions [Re: Joemoy29] #2533797
08/09/18 03:08 PM
08/09/18 03:08 PM
Manitoba, Canada
70NetRT Offline
70NetRT  Offline
Manitoba, Canada
I've been following the one Resto Rick put together.
Resto Rick Assembly Sequence
Re: Order of assembly questions [Re: Joemoy29] #2533806
08/09/18 03:36 PM
08/09/18 03:36 PM
Hazlet nj
Joemoy29 Offline OP
Joemoy29  Offline OP
Hazlet nj
That’s awesome thanks
Re: Order of assembly questions [Re: Joemoy29] #2533847
08/09/18 05:13 PM
08/09/18 05:13 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
You know, it really is up to you . . . on my 70 Sport Satellite, I got the body back from the body shop, and went to work getting all the brake lines, fuel lines, fuel tank on it, before getting the rear suspension on it, also, I assembled the engine and tranny on the K member, along with the steering box and lower control arms . . . also, before dropping the car over the engine/tranny/kmember, made sure to have the brake lines/metering block/prop valve, master cylinder all in place first . . . dropping the car onto the engine/tranny/k member was just too easy, and not required taking hood off, etc . . . pretty sure I got the ac/heater core installed prior to the engine also . . . oh, and the dash as well . . I had my car totally diassembled and rotiserie for body/paint work . . .
Really up to you . . . I wanted to get all items on the car, that are harder to do once you have engine/tranny/k member and rear end installed. Then once it was on wheels, you can do rest of it . . .
Good luck !!
Calgary-20120714-00218.jpgEngine installation.jpgIMG-20120829-00254.jpgSatellite2 Leth May 2013.jpg
Re: Order of assembly questions [Re: Joemoy29] #2533884
08/09/18 06:19 PM
08/09/18 06:19 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Basically, I approach it from the standpoint of easy access and considering the possibility of damage/scratches. Stuff like doors are kind of outside to inside, carpet/belts/console/rear trim/seats are inside to outside. Underhood & undercarriage re-assembly priority is based on easy access.
Take your time, embrace the process, and enjoy it!
Re: Order of assembly questions [Re: Joemoy29] #2533958
08/09/18 09:54 PM
08/09/18 09:54 PM
Lansing, MI
70gtx440dana Offline
Lansing, MI
I am also using the Resto Rick guide. I am not following exactly...I do a bit of jumping around. I am happy to have the guide as reference though.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: Order of assembly questions [Re: 70gtx440dana] #2533963
08/09/18 10:06 PM
08/09/18 10:06 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
It's a pretty good list and I do the same thing with jumping around a bit.
