Re: Change in plans
[Re: BradH]
#2536467
08/14/18 10:31 PM
08/14/18 10:31 PM
Posts: 842 Baltimore,MD
Bill_LBSR
Baltimore,MD
Lol, a few of us definitely remember that car.....was impressed because you always drove it to the track....havent been out with our cars too much this year do to the weather but hopefully I can make it to the MIR Mopar race and do some testing.
LBSR
Re: Change in plans
[Re: BradH]
#2544575
09/02/18 12:24 PM
09/02/18 12:24 PM
Posts: 403 southern Maryland
keefe
southern Maryland
Havent seen that car in a long time......be good to see it back out. So much for my belief that only four other people on the planet remember seeing my car at the track; looks like there are five. Make that six...
1971 duster twister 440, 3380#,509 M/P hyd,906's,full Exhaust,11.06@117.46 1/4,6.95@ 97.03 1/8,1.497 60ft.....
Re: Change in plans
[Re: keefe]
#2544660
09/02/18 02:30 PM
09/02/18 02:30 PM
BradH
Havent seen that car in a long time......be good to see it back out. So much for my belief that only four other people on the planet remember seeing my car at the track; looks like there are five. Make that six... Nope; you & Douglas are two of the original four, Mike Hynes is the third, and John Dallain(sp?) is the fourth. I did forget include Jim Hanrahan, probably because he dropped off the radar years ago. Guess that does make six, though.
Re: Change in plans
[Re: BradH]
#2545789
09/04/18 07:36 PM
09/04/18 07:36 PM
BradH
No updates on my effort, other than my garage isn't quite as cluttered after having spent some time sorting thru sh!t.
Mike's actually made progress, for which I have some photographic evidence. The things I've asked him to take on run the gamut from replacing fuel system components I'm concerned were damaged from extended E10 fuel exposure to handling some body & paint stuff to slightly "re-image" the car per some ideas I had.
I provided him the remaining '70 B5 paint I received w/ the car in 1995, but the color match is off enough that it doesn't appear to have been what the car was actually painted with before I bought it. The front & rear bumpers have been relocated flush w/ the body as w/ '70-72 Challengers, we've gone w/ body-color bumpers & rear tail light trim, the tail light modules are now black, the grille's been blacked out, wheel well bright trim removed... just a bunch of stuff. Still definitely a "20+" footer, yet different.
Re: Change in plans
[Re: Triple Threat]
#2545888
09/04/18 10:52 PM
09/04/18 10:52 PM
Posts: 14,479 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Looks good, any progress is good progress. Exactly. Looks like Mike is getting right after it!!
Re: Change in plans
[Re: BradH]
#2545891
09/04/18 10:54 PM
09/04/18 10:54 PM
Posts: 4,049 Mo.
racerx
Mo.
What's the deal with the patch that was welded inside the engine compartment on the left inner fender? I like the red pin stripe on the grill Also the crack on the left front frame rail is this common on the mopars ? I think someone else has found a crack on the frame rail, Doug with the 64 dodge I believe
Re: Change in plans
[Re: BradH]
#2546128
09/05/18 01:14 PM
09/05/18 01:14 PM
Posts: 17,801 S.E. Michigan
ZIPPY
S.E. Michigan
Good progress. The body color bumpers look really nice on there, I like it better than the black.
Let's see that cool looking hood scoop...
Rich H.
Esse Quam Videri
Re: Change in plans
[Re: racerx]
#2546139
09/05/18 01:27 PM
09/05/18 01:27 PM
Posts: 350 Mequon, WI
gzig5
Mequon, WI
I think that's where the battery mounted originally. Not unusual to have rust from the acid.
Re: Change in plans
[Re: gzig5]
#2546212
09/05/18 03:16 PM
09/05/18 03:16 PM
BradH
I think that's where the battery mounted originally. Not unusual to have rust from the acid. The battery was still in the front when I bought the car. If that area had already rusted when the front end got bent up (per Mike's ), maybe it needed to be patched before the battery tray could be mounted there again.
