Re: Borg Warner T10
[Re: dogdays]
#2533803
08/09/18 03:26 PM
08/09/18 03:26 PM
Posts: 25,726 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The T-10 was used behind lots of big blocks in the day. Sure they could be broken, but they're far from "weak".
The T-85, which is the 3-speed equivalent of the T-10, was used behind the Max Wedge.
Re: Borg Warner T10
[Re: moparpaul66]
#2533879
08/09/18 06:14 PM
08/09/18 06:14 PM
Posts: 3,916 usa
lewtot184
usa
Thanks guys for the replies. Are internal parts the same as Chevy's? What is something like this worth? It's a barn find... Been sitting 40 years but shifts thru all the gears and oil looks good... there were several variations. gm, ford, amc, Studebaker, and mopar had there own variants. some internals may interchange but gear ratios are different between gm, ford and mopar. I know the inputs are different between them. I think what you have is ideal for the collector/restorer; especially mopar, and may be worth something on a trade in with one of the mopar 4spd vendors. ask some questions with vendors or collectors before you start cutting parts up. the t10 is basically the t85 with and extra forward gear in the main case and reverse in the tail. the t85 was supposed to be stronger. neither are up to modern performance standards.
Re: Borg Warner T10
[Re: lewtot184]
#2533941
08/09/18 09:16 PM
08/09/18 09:16 PM
Posts: 10,695 North Dakota
6PakBee
North Dakota
I found this T-10 chart that indicates that the torque capability was determined in part by the first gear ratio.
Re: Borg Warner T10
[Re: lewtot184]
#2534202
08/10/18 02:49 PM
08/10/18 02:49 PM
John_Kunkel
Rio Linda, CA
The one-year-only Mopar T-10 was used behind the 318, 361 and 383 in B-bodies only.
The 318 version had different ratios than the BB; the BB version had the 2.20 1st gear, not sure what the 318 had but it was probably 2.54.
Re: Borg Warner T10
[Re: dogdays]
#2534525
08/11/18 12:10 PM
08/11/18 12:10 PM
6PakBee
North Dakota
6PakBee, that chart is for the Super T-10. I remember looking at it when the Super T-10 came out in the '70s. R. My only reason for posting the chart was to illustrate that with the T-10 it is incorrect to assume all first gear ratios have the same torque capability. But that aside, I have to admit that the progression of the T-10 has been confusing for me. I am under the impression that the original T-10 was in production up to about 1965. Then the first version of the 'super' T-10 was introduced and was in production up until about 1975 when the second version of the 'super' T-10 was produced. But I could be wrong on that. I've been wrong before.
Re: Borg Warner T10
[Re: moparpaul66]
#2534542
08/11/18 12:58 PM
08/11/18 12:58 PM
Posts: 20,725 A collage of whims
topside
A collage of whims
From what I recall, the Chevys had 2 ratios available in T10s: 2.20 or 2.52 low gear, with a fairly wide 3/4 ratio split on the "wide-ratio". You could tell the 3/4 shift difference at the drag strip. My '73 Z28 I ordered/bought new came with a Muncie, and though I can't recall a specific factory application of the Super T10, there had to be one or several, as I recall the various ratio sets as posted. At the time, 4-speeds were still the thing in drag racing (MP classes, etc). Best use of a T10 ever was Ken Dondero driving Bob Panella's blown 301" little panel truck; best I've ever heard, no RPM flare, just beautiful.
Re: Borg Warner T10
[Re: topside]
#2535689
08/13/18 04:03 PM
08/13/18 04:03 PM
dogdays
I don't know what people were calling them at drag strips or in speed shops, but B-W started calling their new version of the T-10 the "Super T-10" in the mid '70s. Chevies generally used Muncies or Saginaw 4-speeds from 1963 until 1974. The Muncies came in two gear ratios, 2.52 and 2.20. The famous M-22 "Rock Crusher" was the strongest with its 2.20 First and straight cut gears, but they were few and far between and weren't all that strong,, meaning a healthy big block could kill one. The Saginaw 4-speed with its cast iron case was the worst as applying too much torque in a certain gear would cause it to slip out of gear. They were only used on lower perf vehicles or behind lower perf engines. The T-10 was used behind engines from all manufacturers and came in a variety of gear ratios and input shaft stickout lengths. The Super T-10 was stock in Chevies but was also sold by speed shops and I don't know what configurations they were made in. As the chart posted above showed, they were available in four flavors as far as gear ratios. I remember there were arguments at the time about which flavor would work best for which engine/car combination.
The Hemi 4-speed was the gearbox of choice for serious drag racers, except for the Ford faithful who preferred the Top Loader.
R.
