'71 Challenger "DODGE" Deck-Lid Emblem placement ? ? ?
#2533396
08/08/18 05:59 PM
08/08/18 05:59 PM
Posts: 3,817 New State
kidmopar
New State
I have / had "?" a Chrysler "Engineering Drawing" that had the specifications for the Correct placement of the 1971 "DODGE" emblem on the Deck / Trunk Lid and after 3 days searching I simply cannot find it ..... Does anyone on our GREAT Forum have a copy of this ??? A BIG THANK YOU ! If you can help Kevin on this one !
Re: '71 Challenger "DODGE" Deck-Lid Emblem placement ? ? ?
[Re: kidmopar]
#2533403
08/08/18 06:12 PM
08/08/18 06:12 PM
Posts: 18,157 Mass
DAYCLONA
Mass
I have / had "?" a Chrysler "Engineering Drawing" that had the specifications for the Correct placement of the 1971 "DODGE" emblem on the Deck / Trunk Lid and after 3 days searching I simply cannot find it ..... Does anyone on our GREAT Forum have a copy of this ??? A BIG THANK YOU ! If you can help Kevin on this one ! I'll send you the bill for services rendered... Mike
[Re: TiMopar]
#2540421
08/23/18 01:35 PM
08/23/18 01:35 PM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
Are these available repro now? Have never seen a repo. I sold the OP "replacement" emblem that is very close
[Re: Morty426]
#2540554
08/23/18 06:35 PM
08/23/18 06:35 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Are these available repro now? Have never seen a repo. I sold the OP "replacement" emblem that is very close C. was the "replacement" emblem the 3 prong type? if so those are available repro from the likes of YO, Classic, etc... the original is a glue/stick on... Mike
[Re: DAYCLONA]
#2540621
08/23/18 09:53 PM
08/23/18 09:53 PM
Morty426
Sacramento CA
Are these available repro now? Have never seen a repo. I sold the OP "replacement" emblem that is very close C. was the "replacement" emblem the 3 prong type? if so those are available repro from the likes of YO, Classic, etc... the original is a glue/stick on... Mike Mike, We are talking about the stick on "Dodge" emblem that goes on the deck lid on a 71 Challenger. The emblem I believe was originally used on a 69 Dart. It has been superseded twice and the one that some people try to pass off is for a 1980 Aspen SE. Sounds like you are talking about the 70 only Challenger side script which has three prongs. I have quite a few originals but I will have to check that out. What about the two pin R/T emblem for the side 0 used on stripe delete and bumblebee stripe cars? Chris
[Re: Morty426]
#2540648
08/23/18 11:10 PM
08/23/18 11:10 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Are these available repro now? Have never seen a repo. I sold the OP "replacement" emblem that is very close C. was the "replacement" emblem the 3 prong type? if so those are available repro from the likes of YO, Classic, etc... the original is a glue/stick on... Mike Mike, We are talking about the stick on "Dodge" emblem that goes on the deck lid on a 71 Challenger. The emblem I believe was originally used on a 69 Dart. It has been superseded twice and the one that some people try to pass off is for a 1980 Aspen SE. Sounds like you are talking about the 70 only Challenger side script which has three prongs. I have quite a few originals but I will have to check that out. What about the two pin R/T emblem for the side 0 used on stripe delete and bumblebee stripe cars? Chris Chris, I'm referring to this 3 pin DODGE emblem for the challenger 71 grille, if I recall it's the same size/font as the trunk emblem including the black out segment on the "E", just suggesting this could be substituted, either use the pins to attach or remove the pins and surgically cut a lettered 2 way tape for it Mike
[Re: Morty426]
#2540698
08/24/18 12:58 AM
08/24/18 12:58 AM
Posts: 18,157 Mass
DAYCLONA
Mass
Mike,
I will have to look at it when I get home but I am doubtful. It looks, from the picture, that the E has a black area in it that I guess supports one of the pins. The rear emblem does not have this.
Chris
This was hashed out about 6 yrs ago...time flies!, Dan/6bblgt put this collage together...
[Re: Morty426]
#2541316
08/25/18 05:33 PM
08/25/18 05:33 PM
kidmopar
New State
Are these available repro now? Have never seen a repo. I sold the OP "replacement" emblem that is very close You did ? Why ? Do I not remember this ? ? ? I actually just purchased an "NOS" emblem from gentleman in Arizona ........ I also have an NOS 3 - Prong that goes in Front Grille
[Re: kidmopar]
#2541469
08/26/18 05:59 AM
08/26/18 05:59 AM
Morty426
Sacramento CA
Are these available repro now? Have never seen a repo. I sold the OP "replacement" emblem that is very close You did ? Why ? Do I not remember this ? ? ? I actually just purchased an "NOS" emblem from gentleman in Arizona ........ I also have an NOS 3 - Prong that goes in Front Grille I thought it was you back when you had the green N96 car. Maybe I am confusing you with someone else. All you Mopar guys look the same
[Re: 71vert340]
#2542318
08/28/18 03:31 AM
08/28/18 03:31 AM
Morty426
Sacramento CA
So I have my original DODGE trunk emblem for my 71 Challenger although the tape no longer sticks but is still there. Would it be better to use an X-acto knife and apply new double stick tape after removing the old tape or use some emblem adhesive to the old tape and glue it to the trunk lid? Terry Get some 3M double sided emblem tape and leave the original tape on it
