2000 Cherokee Classic XJ fuel pump #2531784
08/05/18 04:17 AM
08/05/18 04:17 AM
Phoenix, AZ
Belvedere1 Offline OP
Phoenix, AZ
If you were going to replace one with something other than a factory Mopar unit, what aftermarket brand would you use? I'm going on 260K on the original pump and looking to preempt a problem.
Re: 2000 Cherokee Classic XJ fuel pump [Re: Belvedere1] #2532133
08/06/18 01:41 AM
08/06/18 01:41 AM
garnett kansas
rhad Offline
rhad  Offline
garnett kansas
carter if you can find one!!
my ladder of success is missing some rungs
Re: 2000 Cherokee Classic XJ fuel pump [Re: rhad] #2532630
08/07/18 02:14 AM
08/07/18 02:14 AM
Phoenix, AZ
Phoenix, AZ
I never knew they made an in-tank factory replacement but I'll start searching. Thanks.
Re: 2000 Cherokee Classic XJ fuel pump [Re: Belvedere1] #2533151
08/08/18 03:53 AM
08/08/18 03:53 AM
Pennsylvania
P
polaris400cc Offline
P
Pennsylvania
Carter p88020
Carter P74186
Carter P90010
If you are looking for pump only and not the whole unit as one piece.
