Re: Need LA Small Block Bolt Lengths - Available info?
[Re: GoodysGotaCuda]
#2532658
08/07/18 07:25 AM
08/07/18 07:25 AM
Posts: 140 Akron, ohio
76orangewagon
Akron, ohio
AMK Products sells a complete engine fastener kit with all the bolts you need, I also have seen individual kits on eBay for individual components like water pump bolt kits.
[Re: 500ciDuster]
#2537383
08/16/18 09:13 PM
08/16/18 09:13 PM
RapidRobert
FYI block front pump/tcover bolt holes: Dr side top to bottom: (1) dry (2) wet (3) wet & #1 cyl wall is only 5/8" in from the block face (4) dry. Pass side top to bottom: (1) wet into valley (oil) (2) wet (coolant) (3) wet (coolant) (4) dry. Cam plate holes: (1) lower two are into crank area (2) dr top is blind (3) pass top into valley (oil) & that is the hole you want the OE bolt with the 1/8" hole in it for a drip or drill your own bolt. Others will clarify but iirc you want 1&1/4 times (1&1/2 times?) the bolt dia, that amt of thread engagement into the female block threads.
