Correct finish 1969 charger dual exh hanger #2061575
04/25/16 07:14 PM
04/25/16 07:14 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
How should this be finished from the factory?
Gloss black?
Semi gloss black??
Bare metal?????
This is on a 1969 hemi charger
Re: Correct finish 1969 charger dual exh hanger [Re: domingo] #2062070
04/26/16 03:53 PM
04/26/16 03:53 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Clear cad
Re: Correct finish 1969 charger dual exh hanger [Re: Morty426] #2062083
04/26/16 04:08 PM
04/26/16 04:08 PM
muskegon MI
v cummins Offline
v cummins  Offline
muskegon MI
Bare metal
Re: Correct finish 1969 charger dual exh hanger [Re: domingo] #2062280
04/26/16 09:33 PM
04/26/16 09:33 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
so?
Re: Correct finish 1969 charger dual exh hanger [Re: domingo] #2062281
04/26/16 09:33 PM
04/26/16 09:33 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
My ICCA reference manual doesnt say a thing about this part...or maybe im missing it, but I cant find anything on it.
Re: Correct finish 1969 charger dual exh hanger [Re: domingo] #2063226
04/28/16 08:27 AM
04/28/16 08:27 AM
Mass
charge70 Offline
charge70  Offline
Mass
Domingo,I'm restoring my brothers 70 Charger R/T right now.An original car he's owned since 1982.When I removed that hanger bracket it was bare steel no paint or plating.All it had on it was surface rust and a small splattering of undercoating when they undercoated the bottom of the car.Also,when I removed the hanger you could see the grey body dip primer color under the mounting flanges,so this piece is put on after the car was run thru the dip tanks.Hope this helps you out.I have some pics,PM me your e-mail address and I can send a few to you. John
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
Re: Correct finish 1969 charger dual exh hanger [Re: domingo] #2531565
08/04/18 05:41 PM
08/04/18 05:41 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Great info. I had not seen this reply, this was quite a while ago!!!
Re: Correct finish 1969 charger dual exh hanger [Re: domingo] #2531588
08/04/18 07:16 PM
08/04/18 07:16 PM
Sweden
71redcuda Offline
71redcuda  Offline
Sweden
Bare metal.
Re: Correct finish 1969 charger dual exh hanger [Re: charge70] #2531631
08/04/18 09:21 PM
08/04/18 09:21 PM
People's Republic of Kali
70runner Offline
70runner  Offline
iagree
Daughter's 69 R/T survivor, samo samo. She's 3rd owner.
