Torsion bar anchor in lower cont. arm slipping #2529989
08/01/18 01:56 PM
08/01/18 01:56 PM
Ohio
jlatessa Offline OP
jlatessa  Offline OP
Ohio
This on a 70 Charger RT, changed to heavier bars this year to remedy what we thought was a sagging bar on driver's side.
Now sagging is apparent on that side again.
Figured bar anchor in rear cross member was the culprit, but today's inspection revealed movement in lower control arm asbly.
Looks like we can loosen the suspension to the point where you install a new bar and weld the perimeter of the front anchor.
Does this sound like a fix, or am I missing something?
Thanks, Joe
Re: Torsion bar anchor in lower cont. arm slipping [Re: jlatessa] #2531132
08/03/18 07:35 PM
08/03/18 07:35 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
The front t bar socket is supposed to pivot within the control arm, with the blade; that part that the adjustment bolt contacts to put tension on the bar.
Where do you suspect movement that should not be and think you need to weld? A picture is worth a thousand words..is the LCA t bar socket somehow loose fron the blade? LCA bushing intact?
Re: Torsion bar anchor in lower cont. arm slipping [Re: jlatessa] #2531182
08/03/18 08:59 PM
08/03/18 08:59 PM
Northern California
lilcuda Offline
lilcuda  Offline
Northern California
Definitely need pics, or a video if you can have someone push up and down on the fender while videoing the control arm.
Possibly a broken LCA mount in the k member? Or is that what you are trying to describe?
Again, pics needed.
'67 is an abbreviation of 1967
67' is an abbreviation of 67 feet
They are not interchangeable.
Re: Torsion bar anchor in lower cont. arm slipping [Re: jlatessa] #2531218
08/03/18 10:00 PM
08/03/18 10:00 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
