Fuel pump question.nn
#2528818
07/29/18 10:51 PM
07/29/18 10:51 PM
Posts: 773 Crofton, Ky.
rattler
Crofton, Ky.
I have put an 05 model 5.7 and Nag-1 auto in my 64 wagon. Question is, what fuel pump can I use? This will be factory fuel injection. I can't mount the pump in the tank as this is a wagon with the stock tank.
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
Re: Fuel pump question.nn
[Re: rattler]
#2528878
07/30/18 01:17 AM
07/30/18 01:17 AM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
I'd recommend the tank inc style pump and convert you oem. This is how I did a coronet wagon for a 6.1 swap. You can run an external pump, but you'd have to keep the tank over to be safe. Or add a sump to the tank.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: Silver70]
#2529054
07/30/18 02:48 PM
07/30/18 02:48 PM
Posts: 286 Marysville, OH
mrploww
Marysville, OH
I'd recommend the tank inc style pump and convert you oem. This is how I did a coronet wagon for a 6.1 swap. You can run an external pump, but you'd have to keep the tank over to be safe. Or add a sump to the tank. Any pics of the 6.1 swap or fuel tank? I am getting ready to put a 6.1 in my '64 Plymouth wagon.
'64 Plymouth Belvedere 9 passenger surf wagon
[Re: Silver70]
#2529325
07/30/18 11:24 PM
07/30/18 11:24 PM
rattler
Crofton, Ky.
I don't know where the tank is in a 67, but in a 64, it's turned up on it's side in the driver side quarter panel.
[Re: rattler]
#2529669
07/31/18 06:46 PM
07/31/18 06:46 PM
Andrewh
consider a surge tank instead. not a hemi, but efi in a 65 coronet vert. I just got a new tank and had it coated and decided to put in efi. Didn't want to cut and weld the brand new tank. or use the areomotive kit as I wanted to keep my gauge as well. I don't recommend the surge tank I got, as I found it was hard to seal up because it was round. works fine, just a pain to set up. https://store.034motorsport.com/fully-en...-fuel-pump.htmlSo a member on here sells one, also fi tech has the commander setup as well.
[Re: dogdays]
#2529791
08/01/18 12:30 AM
08/01/18 12:30 AM
rattler
Crofton, Ky.
Dogdays, thats my situation. I am keeping the stock tank, and keeping the spare tire in the well where it belongs. I figured I would mount the pump as close as I could, but I wasn't sure what brand of pump others were using.
[Re: Andrewh]
#2530050
08/01/18 04:25 PM
08/01/18 04:25 PM
mrploww
Marysville, OH
consider a surge tank instead. not a hemi, but efi in a 65 coronet vert. I just got a new tank and had it coated and decided to put in efi. Didn't want to cut and weld the brand new tank. or use the areomotive kit as I wanted to keep my gauge as well. I don't recommend the surge tank I got, as I found it was hard to seal up because it was round. works fine, just a pain to set up. https://store.034motorsport.com/fully-en...-fuel-pump.htmlSo a member on here sells one, also fi tech has the commander setup as well. How does the surge tank work? You don't have to have a return line to tank?
[Re: rattler]
#2530272
08/01/18 11:47 PM
08/01/18 11:47 PM
Posts: 2,254 IL
furious70
IL
I've been efi since 2009 and just used a walbro 255 hanging on the frame rail with a pre filter and the sock removed from the stock pickup. No issues
70 Sport Fury 68 Charger 69 Coronet 72 RR
