05 CTD auto trans fluid capacity? #2525839
07/23/18 01:04 PM
07/23/18 01:04 PM
Penna
70satelliteguy Offline OP
Penna
My book says to use ATF+4 fluid but does not say how much to do oil change.
Thanks Mike
Re: 05 CTD auto trans fluid capacity? [Re: 70satelliteguy] #2525843
07/23/18 01:23 PM
07/23/18 01:23 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I have blown dozens on the ground... realcrazy Are you just changing fluid or after a rebuild? 17 quarts after a rebuild.
JB Rhinehart, Realist
A-Body's RULE!
Re: 05 CTD auto trans fluid capacity? [Re: Rhinodart] #2525872
07/23/18 02:45 PM
07/23/18 02:45 PM
Penna
Penna
Just changing the oil in the transmission.
" 17 quarts after a rebuild. " REALLY! Over 4 gallons !!!
Oil change in the Motor takes 2 gallons. I would have never guessed the tranny would take that much!
Thanks Mike
Re: 05 CTD auto trans fluid capacity? [Re: 70satelliteguy] #2525883
07/23/18 03:12 PM
07/23/18 03:12 PM
Guitar Jones Offline
Actually the engine takes 3 gallons.
On the trans you'd probably need 8 or 9 quarts if you loosen the valve body and drain as much as you can.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: 05 CTD auto trans fluid capacity? [Re: Guitar Jones] #2526333
07/24/18 12:24 PM
07/24/18 12:24 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Quite a bit to run the overdrive unit, don't ever run it low, DAMHIK! flame
A-Body's RULE!
