Tires going away?
#2525454
07/22/18 05:59 PM
07/22/18 05:59 PM
Posts: 690 New Hampshire, USA
oldiron
New Hampshire, USA
How much do you lose in the 60' as the tires get beat up? MT29.5 x 15S Was testing last week with my MTs and I seem to have lost about .03 in the 60' This wouldn't bother me except when I'm running 10.0 index which will be doing next weekend
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge New New Best: 10.56 @129 68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up https://www.youtube.com/watch?v=T4jDLKwd9Gs
Re: Tires going away?
[Re: oldiron]
#2525466
07/22/18 06:21 PM
07/22/18 06:21 PM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
When your that consistent on a regular basis and can tell when you fall off like that the sidewall is gone.I have read about guys that get 75 passes off before they are done. I'm justa street car tuna fish or most likely an exhibitionist.
[Re: hemi-itis]
#2525478
07/22/18 06:41 PM
07/22/18 06:41 PM
Posts: 20,116 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Mine went from 1.25-1.27 to 1.32-1.35
[Re: oldiron]
#2525484
07/22/18 06:49 PM
07/22/18 06:49 PM
oldiron
New Hampshire, USA
Many thanks. That sounds about the same for me. But always hard to know if tires or clutch adjustment. Went from 1.35 to 36 to 1.40, 41 Yep, have tubes in them. Little holes are pretty close to being gone Ordered new tires last week from McCormick, one arrived with a cut and gouge Couldn't get through to them on Friday.
[Re: oldiron]
#2525519
07/22/18 07:56 PM
07/22/18 07:56 PM
Posts: 1,098 Massillon, Ohio
cudatom
Massillon, Ohio
My cuda I got about 150 runs on the tires and tbey were still good when I parked the car. That was running 10 teens to mid 10.2's at 3500lbs. The tires were Phoenix 29.5 x 11.5w.
My wagon running Hoosiers at only 7.0's in the 1/8 at 4000lbs didn't last 75 runs. I could feel the difference atlaunch. The tires started balling up and one time I would hook the next not so well. Difference was usually only .03-4.
Different tires just seem to last longer. Wish. I coulduse Phoenix on my wagon but they don't have a size that will fit due to their large section width.
Ok
