any gen3 heads/exhaust manifolds that can be flipped
#2525299
07/22/18 12:37 PM
07/22/18 12:37 PM
Posts: 2,252 IL
furious70
IL
facing forwards for turbocharging like the magnum manifolds or big blocks?
70 Sport Fury 68 Charger 69 Coronet 72 RR
Re: any gen3 heads/exhaust manifolds that can be flipped
[Re: furious70]
#2525327
07/22/18 01:40 PM
07/22/18 01:40 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
I believe 6.1s can, but they really aren't that difficult to make yourself... basically an afternoon of work I made my own.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: furious70]
#2525349
07/22/18 02:33 PM
07/22/18 02:33 PM
Posts: 2,252 IL
furious70
IL
6.1 heads only have a reversible bolt pattern or only the 6.1 manifolds fit flipped? Difficult...matter of perspective I guess. I used OEM manifolds on my 383 because for a street car that was going to see a bazillion heat cycles I didn't trust myself to make anything that would hold up (would have done weld el based logs if I had to)
[Re: furious70]
#2525378
07/22/18 03:32 PM
07/22/18 03:32 PM
Silver70
Rust Belt, SW PA
I think I read only 6.1s have enough material to be able to redrill to swap sides... but could be wrong there. I don't think any can be flipped.
[Re: furious70]
#2525417
07/22/18 04:47 PM
07/22/18 04:47 PM
Posts: 2,252 IL
furious70
IL
Yes, I meant swapped side to side but I wrote flipped. Flipped might help with stock suspension clearance but I would expect them to interfere with the heads at the exit. The weird RV/van big block ones I used are the only mopar manifolds I know of for any engine that can be flipped upside down and clear as well as still get spark plugs in.
[Re: furious70]
#2525422
07/22/18 04:56 PM
07/22/18 04:56 PM
Posts: 2,252 IL
furious70
IL
hmmm, these look like they would swap with no redrilling....if they don't interfere with the ps, alt, or susp?
https://www.ebay.com/itm/MOPAR-SRT-6-1-6-2-6-4-Exhaust-Manifold-Set-5038756AA-and-5038757AA/163152186476?hash=item25fca0cc6c%3Ag%3APhcAAOSw2yNbTN6K&_sop=16&_nkw=6.1+manifolds&_sacat=6028&_from=R40&rt=nc&LH_TitleDesc=0%7C0
https://www.ebay.com/itm/06-07-08-09-Jeep-Grand-Cherokee-SRT-Exhaust-Manifolds-Headers-SRT8-6-1L-6-1/202364965214?hash=item2f1de4515e%3Ag%3AE0sAAOSwP7JbQ5zz&_sop=16&_nkw=6.1+manifolds&_sacat=6028&_from=R40&rt=nc&LH_TitleDesc=0%7C0
