08 Camry hybrid inverter coolant #2525402
07/22/18 04:30 PM
07/22/18 04:30 PM
Phoenix, AZ
Belvedere1 Offline OP
Phoenix, AZ
Just did an oil change and noticed the reservoir was low. By color it appears to be the same as the engine coolant. Is this a dealer only purchase, is it OK just to "top it off"?
Re: 08 Camry hybrid inverter coolant [Re: Belvedere1] #2525421
07/22/18 04:54 PM
07/22/18 04:54 PM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
IIRC, it has the red LongLife coolant in it. Owners manual will tell you. Saw them mixed a good bit at the dealer before I retired. Only problem with mixing is that it changes the color and makes it look dirty. It's only a little more expensive than a parts house or Walmart so if you have a local dealer I would source it there.
twocents
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: 08 Camry hybrid inverter coolant [Re: I_bleed_MOPAR] #2525437
07/22/18 05:32 PM
07/22/18 05:32 PM
Phoenix, AZ
Phoenix, AZ
I just stopped at O'reillys for some stuff and they don't have anything for hybrids or even an equivalent coolant for the inverter. I'll just let the dealer handle this one.
Re: 08 Camry hybrid inverter coolant [Re: Belvedere1] #2525487
07/22/18 06:57 PM
07/22/18 06:57 PM
Chicago
PurpleBeeper Offline
Chicago
Good move. That Toyota inverter stuff is patented, so only Toyota will have it I believe. It's not a complicated coolant, but it is ULTRA high purity & is not "typical antifreeze"
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
