any gen3 heads/exhaust manifolds that can be flipped #2525299
07/22/18 12:37 PM
07/22/18 12:37 PM
IL
furious70 Offline OP
IL
facing forwards for turbocharging like the magnum manifolds or big blocks?
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: any gen3 heads/exhaust manifolds that can be flipped [Re: furious70] #2525327
07/22/18 01:40 PM
07/22/18 01:40 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I believe 6.1s can, but they really aren't that difficult to make yourself... basically an afternoon of work I made my own.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: any gen3 heads/exhaust manifolds that can be flipped [Re: furious70] #2525349
07/22/18 02:33 PM
07/22/18 02:33 PM
IL
IL
6.1 heads only have a reversible bolt pattern or only the 6.1 manifolds fit flipped?
Difficult...matter of perspective I guess. smile I used OEM manifolds on my 383 because for a street car that was going to see a bazillion heat cycles I didn't trust myself to make anything that would hold up (would have done weld el based logs if I had to)
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: any gen3 heads/exhaust manifolds that can be flipped [Re: furious70] #2525378
07/22/18 03:32 PM
07/22/18 03:32 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I think I read only 6.1s have enough material to be able to redrill to swap sides... but could be wrong there. I don't think any can be flipped.
Re: any gen3 heads/exhaust manifolds that can be flipped [Re: furious70] #2525417
07/22/18 04:47 PM
07/22/18 04:47 PM
IL
IL
Yes, I meant swapped side to side but I wrote flipped. Flipped might help with stock suspension clearance but I would expect them to interfere with the heads at the exit. The weird RV/van big block ones I used are the only mopar manifolds I know of for any engine that can be flipped upside down and clear as well as still get spark plugs in.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: any gen3 heads/exhaust manifolds that can be flipped [Re: furious70] #2525422
07/22/18 04:56 PM
07/22/18 04:56 PM
IL
IL
hmmm, these look like they would swap with no redrilling....if they don't interfere with the ps, alt, or susp?
https://www.ebay.com/itm/MOPAR-SRT-6-1-6-2-6-4-Exhaust-Manifold-Set-5038756AA-and-5038757AA/163152186476?hash=item25fca0cc6c%3Ag%3APhcAAOSw2yNbTN6K&_sop=16&_nkw=6.1+manifolds&_sacat=6028&_from=R40&rt=nc&LH_TitleDesc=0%7C0
https://www.ebay.com/itm/06-07-08-09-Jeep-Grand-Cherokee-SRT-Exhaust-Manifolds-Headers-SRT8-6-1L-6-1/202364965214?hash=item2f1de4515e%3Ag%3AE0sAAOSwP7JbQ5zz&_sop=16&_nkw=6.1+manifolds&_sacat=6028&_from=R40&rt=nc&LH_TitleDesc=0%7C0
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: any gen3 heads/exhaust manifolds that can be flipped [Re: furious70] #2525524
07/22/18 08:01 PM
07/22/18 08:01 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
The flanges I bought to build mine are the same as what the srt headers have like in those listings. To face them forward, you could drill the holes or slot the bottoms to line up. The non srt don't have material where you would need to relocate the holes/slots like those do.
