#2525299 - 07/22/18 10:37 AM any gen3 heads/exhaust manifolds that can be flipped
furious70 Offline
Loc: IL
facing forwards for turbocharging like the magnum manifolds or big blocks?
#2525327 - 07/22/18 11:40 AM Re: any gen3 heads/exhaust manifolds that can be flipped [Re: furious70]
Silver70 Offline
Loc: Rust Belt, SW PA
I believe 6.1s can, but they really aren't that difficult to make yourself... basically an afternoon of work I made my own.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
99 Trans Am, 66 GTO, 06 Magnum RT AWD
#2525349 - 07/22/18 12:33 PM Re: any gen3 heads/exhaust manifolds that can be flipped [Re: furious70]
furious70 Offline
Loc: IL
6.1 heads only have a reversible bolt pattern or only the 6.1 manifolds fit flipped?
Difficult...matter of perspective I guess. smile I used OEM manifolds on my 383 because for a street car that was going to see a bazillion heat cycles I didn't trust myself to make anything that would hold up (would have done weld el based logs if I had to)
Edited by furious70 (07/22/18 12:37 PM)
#2525378 - 07/22/18 01:32 PM Re: any gen3 heads/exhaust manifolds that can be flipped [Re: furious70]
Silver70 Offline
I think I read only 6.1s have enough material to be able to redrill to swap sides... but could be wrong there. I don't think any can be flipped.
#2525417 - 07/22/18 02:47 PM Re: any gen3 heads/exhaust manifolds that can be flipped [Re: furious70]
furious70 Offline
Loc: IL
Yes, I meant swapped side to side but I wrote flipped. Flipped might help with stock suspension clearance but I would expect them to interfere with the heads at the exit. The weird RV/van big block ones I used are the only mopar manifolds I know of for any engine that can be flipped upside down and clear as well as still get spark plugs in.
#2525422 - 07/22/18 02:56 PM Re: any gen3 heads/exhaust manifolds that can be flipped [Re: furious70]
furious70 Offline
Loc: IL
hmmm, these look like they would swap with no redrilling....if they don't interfere with the ps, alt, or susp?
https://www.ebay.com/itm/MOPAR-SRT-6-1-6-2-6-4-Exhaust-Manifold-Set-5038756AA-and-5038757AA/163152186476?hash=item25fca0cc6c%3Ag%3APhcAAOSw2yNbTN6K&_sop=16&_nkw=6.1+manifolds&_sacat=6028&_from=R40&rt=nc&LH_TitleDesc=0%7C0
https://www.ebay.com/itm/06-07-08-09-Jeep-Grand-Cherokee-SRT-Exhaust-Manifolds-Headers-SRT8-6-1L-6-1/202364965214?hash=item2f1de4515e%3Ag%3AE0sAAOSwP7JbQ5zz&_sop=16&_nkw=6.1+manifolds&_sacat=6028&_from=R40&rt=nc&LH_TitleDesc=0%7C0
#2525524 - 07/22/18 06:01 PM Re: any gen3 heads/exhaust manifolds that can be flipped [Re: furious70]
Silver70 Offline
The flanges I bought to build mine are the same as what the srt headers have like in those listings. To face them forward, you could drill the holes or slot the bottoms to line up. The non srt don't have material where you would need to relocate the holes/slots like those do.
25,425 Registered Members
191,754 Topics
2001 V-10 transmission ?
by moparx
08/14/18 10:02 AM
71 Challenger
by Neil
08/14/18 09:30 AM
Smooth Shifting With American Powertrain’s White Lightning
by Rustymuscle
08/14/18 08:49 AM
calculating peak rpm hp
by mopar dave
08/14/18 08:21 AM
