Re: Any1 use the NAG1 or torqueflite 8 in an old mopar?
[Re: furious70]
#2536126
08/14/18 12:58 PM
08/14/18 12:58 PM
Posts: 2,254 IL
furious70
IL
Is that from the interwebs or do you have all 3 and can take more photos? If so I'd really appreciate it!
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: furious70]
#2536221
08/14/18 03:38 PM
08/14/18 03:38 PM
Posts: 2,254 IL
furious70
IL
Darius had to raise his tunnel in a B body per his build thread, didn't look terrible. I'd like to see more photos and measurements to gauge the fit.
[Re: furious70]
#2537285
08/16/18 05:27 PM
08/16/18 05:27 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
The crossmember is further back on an e-body vs b-body... that makes a world of difference in a 518 swap also. I imagine it's the same deal for these transmissions.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: furious70]
#2537466
08/17/18 01:09 AM
08/17/18 01:09 AM
Posts: 2,254 IL
furious70
IL
going back through cbodydrydock.com threads I found this pic showing tunnel mods when running the 545RFE. Now I want the dimensions of the 545RFE as well to compare :P
[Re: furious70]
#2538965
08/20/18 12:18 PM
08/20/18 12:18 PM
Posts: 2,254 IL
furious70
IL
I was changing the oil in my 2012 charger this weekend with the 3.6 and TF8. I couldn't get any good measurements of the TF8 in the car but it's near 30" bellhousing to mount and at the mount still seemed to be 9" tall (9" diameter). It's a big dude. The tunnel in the car looks huge from the underside.
[Re: furious70]
#2543932
08/31/18 05:57 PM
08/31/18 05:57 PM
Posts: 2,254 IL
furious70
IL
hmmm, I know they made them for a long time, but is there actually a hydro/vac controlled 5spd version that handles any real torque? That would be really intriguing if you can bolt on a hemi bell...
[Re: furious70]
#2543979
08/31/18 08:08 PM
08/31/18 08:08 PM
Posts: 2,254 IL
furious70
IL
wikipedia only says this
722.5 — 5-speed (hydraulically controlled 4-speed with additional electrically controlled 5th overdrive gear)
no actual page for it, but a page for the 4spd before and the 722.6, of course :P
google isn't being my friend, can't find much about the trans, it's construction, or torque rating
[Re: furious70]
#2543981
08/31/18 08:15 PM
08/31/18 08:15 PM
Posts: 2,254 IL
furious70
IL
this one does not have a bolt on bell and is much skinnier than a .6
https://www.ebay.com/itm/94-97-Mercedes-R129-SL320-Automatic-Transmission-Assembly-722-507-76k/113145830970?hash=item1a58045e3a:g:VAYAAOSw4v1bRvto
this might be worth $10 tho lol
https://www.ebay.com/itm/ATSG-Mercedes-722-5-manual/273422192424?hash=item3fa93b8f28:g:QRwAAOSwQ19arXdx
[Re: furious70]
#2544054
09/01/18 12:01 AM
09/01/18 12:01 AM
Posts: 2,254 IL
furious70
IL
I asked Russell Drake about them and he said the 722.5 is weak, only went behind v6.
