Reproduction Date Coded Resonators Keep Rusting Out #2524444
07/20/18 11:14 AM
07/20/18 11:14 AM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Who makes a good restoration date coded muffler and resonator that will last more than 5 years? These things do not hold up.
Where would you buy your next pair?
Re: Reproduction Date Coded Resonators Keep Rusting Out [Re: Sammy] #2524447
07/20/18 11:16 AM
07/20/18 11:16 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
No mention of vehicle, but ECS might be your first and maybe only stop to shop
Re: Reproduction Date Coded Resonators Keep Rusting Out [Re: Sammy] #2524615
07/20/18 04:08 PM
07/20/18 04:08 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
When I worked at an exhaust shop, we would use an awl to make a small hole in the muffler right above the rear seam. That lets the water drain out of them and they last a lot longer. I'm not sure you're interested in doing that though since you're looking for date coded parts. Just throwing that out there.
Re: Reproduction Date Coded Resonators Keep Rusting Out [Re: burdar] #2524778
07/20/18 10:13 PM
07/20/18 10:13 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
It also is dependent on the amount it is driven at one time.
A trailer queen that is only driven super short distances will greatly suffer from condensation in the exhaust system
Re: Reproduction Date Coded Resonators Keep Rusting Out [Re: DAYCLONA] #2525106
07/21/18 09:40 PM
07/21/18 09:40 PM
Long Island, NY
shakerjoe Offline
shakerjoe  Offline
Long Island, NY
I hope the ECS system will be up to snuff Mike, I ordered their full '71 system for my Cuda last week at Carlisle to replace my TTI X pipe setup...last thing I want to hear...though won't be daily driving in rain and snow as they were originally were, will have to check on weep holes...
Re: Reproduction Date Coded Resonators Keep Rusting Out [Re: Sammy] #2525158
07/22/18 12:43 AM
07/22/18 12:43 AM
So Near, Yet So Far
topside Offline
topside  Offline
So Near, Yet So Far
Like Morty & Burdar said: need to get the exhaust system warm enough to burn off the condensation. I've also seen mufflers with a small (1/8"?) hole in an end cap for a drain, that looked like they were made that way.
Re: Reproduction Date Coded Resonators Keep Rusting Out [Re: Sammy] #2525223
07/22/18 03:59 AM
07/22/18 03:59 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Minimum drive should be 15 miles or 15 minutes one way to be certain the temperature of the exhaust system is above steam or 212*F. Look for internals made of aluminized steel or stainless 409 or stainless 304. These 3 grades are good, better, and best. If the manufacturer doesn't name one of these 3 metals, it's likely carbon steel is being used, the shortest lived of all.
See:
https://www.maperformance.com/blogs/mape...w-these-details
Re: Reproduction Date Coded Resonators Keep Rusting Out [Re: Sammy] #2525239
07/22/18 09:50 AM
07/22/18 09:50 AM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
How much is ECS over the axle pipe system resonators and mufflers date coded? There is no price on his website.
I've always ran my car and got it up to operating temperature. 2nd set of mufflers and it is kept in a climate controlled garage.
Re: Reproduction Date Coded Resonators Keep Rusting Out [Re: Sammy] #2525284
07/22/18 12:06 PM
07/22/18 12:06 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
As mentioned "up to temperature" does not matter. You need at least 15 minutes of drive time at temp. Each time.
Re: Reproduction Date Coded Resonators Keep Rusting Out [Re: Sammy] #2525585
07/22/18 10:12 PM
07/22/18 10:12 PM
WA
tman Offline
tman  Offline
WA
Short drives kills muffs and resonators. Doesn't matter where you get them unless they are stainless. Of course they were never made in SS. As mentioned, long drives or get them really hot. Otherwise water is just sitting in there.
Re: Reproduction Date Coded Resonators Keep Rusting Out [Re: Sammy] #2525955
07/23/18 05:03 PM
07/23/18 05:03 PM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
Did the originals last any longer?
Re: Reproduction Date Coded Resonators Keep Rusting Out [Re: Montclaire] #2526404
07/24/18 02:05 PM
07/24/18 02:05 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Two sets of Dynomax Super Turbos in 26 yrs, first set had AP resonators. I put a 1/8" hole at bottom of outlet on both muffler and resonator, first set lasted 17 yrs, second still on without resonator.
